Base 3.14.8.2 builds just fine, medm too. But with alh I get a compiler error: [kp1pc10:extensions/src/alh] bkolb% make make -C O.darwin-ppc -f ../Makefile.Host T_A=darwin-ppc BUILD_TYPE=Host install gcc -ansi -pedantic -D_POSIX_C_SOURCE=199506L -O3 -Wall -Wtraditional -Wmissing-prototypes -Wstrict-prototypes -DFLDNAME_SZ=4 -fPIC -D_REENTRANT -DUNIX -no-cpp-precomp -I. -I.. -I../os/Darwin -I../os/default -I/sw/include -I/usr/X11R6/include -I../../../include/os/Darwin -I../../../include -I/epics/base-3.14.8.2/include/os/Darwin -I/epics/base-3.14.8.2/include -I/sw/include -I/usr/X11R6/include -c ../alCaCommon.c In file included from /epics/base-3.14.8.2/include/alarm.h:22, from ../alCaCommon.c:29: /epics/base-3.14.8.2/include/shareLib.h:138:2: warning: suggest not using #elif in traditional C ...snip ../alCaCommon.c: In function 'nextGroupChannel': ../alCaCommon.c:73: warning: traditional C rejects ISO C style function definitions ../alCaCommon.c: In function 'alCaCancel': ../alCaCommon.c:121: warning: traditional C rejects ISO C style function definitions ../alCaCommon.c: In function 'alSetNotConnected': ../alCaCommon.c:150: warning: traditional C rejects ISO C style function definitions ../alCaCommon.c: In function 'alPutGblAckT': ../alCaCommon.c:183: warning: traditional C rejects ISO C style function definitions ../alCaCommon.c: In function 'alProcessCA': ../alCaCommon.c:209: warning: traditional C rejects ISO C style function definitions ../alCaCommon.c: In function 'registerCA': ../alCaCommon.c:217: warning: traditional C rejects ISO C style function definitions ../alCaCommon.c:233: warning: traditional C rejects string constant concatenation ../alCaCommon.c:242: warning: traditional C rejects string constant concatenation ../alCaCommon.c: At top level: ../alCaCommon.c:278: warning: function declaration isn't a prototype ../alCaCommon.c: In function 'alCaCancel': ../alCaCommon.c:121: internal compiler error: Bus error Please submit a full bug report, with preprocessed source if appropriate. See <URL:http://developer.apple.com/bugreporter> for instructions. make[1]: *** [alCaCommon.o] Error 1 make: *** [install.darwin-ppc] Error 2 [kp1pc10:extensions/src/alh] bkolb% gcc -v Using built-in specs. Target: powerpc-apple-darwin8 Configured with: /private/var/tmp/gcc/gcc-5026.obj~19/src/configure --disable-checking --prefix=/usr --mandir=/share/man --enable-languages=c,objc,c++,obj-c++ --program-transform-name=/^[cg][^+.-]*$/s/$/-4.0/ --with-gxx-include-dir=/include/gcc/darwin/4.0/c++ --build=powerpc-apple-darwin8 --host=powerpc-apple-darwin8 --target=powerpc-apple-darwin8 Thread model: posix gcc version 4.0.0 (Apple Computer, Inc. build 5026) Any clue? Burkhard
ANJ, 02 Sep 2010 |
![]() · Download · Search · IRMIS · Talk · Documents · Links · Licensing · |
