1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Problem building alh on Mac OSX
To: Burkhard Kolb <[email protected]>
Cc: "'[email protected]'" <[email protected]>
Date: Fri, 10 Mar 2006 21:28:41 +0900
Burkhard Kolb wrote:
I just upgraded my Mac to 10.4.5, and started a new EPICS build.
Base 3.14.8.2 builds just fine, medm too. But with alh I get a compiler error:
[kp1pc10:extensions/src/alh] bkolb% make
make -C O.darwin-ppc -f ../Makefile.Host T_A=darwin-ppc BUILD_TYPE=Host install
gcc -ansi -pedantic -D_POSIX_C_SOURCE=199506L -O3 -Wall -Wtraditional -Wmissing-prototypes -Wstrict-prototypes -DFLDNAME_SZ=4 -fPIC -D_REENTRANT -DUNIX -no-cpp-precomp -I. -I.. -I../os/Darwin -I../os/default -I/sw/include -I/usr/X11R6/include -I../../../include/os/Darwin -I../../../include -I/epics/base-3.14.8.2/include/os/Darwin -I/epics/base-3.14.8.2/include -I/sw/include -I/usr/X11R6/include -c ../alCaCommon.c
In file included from /epics/base-3.14.8.2/include/alarm.h:22,
from ../alCaCommon.c:29:
/epics/base-3.14.8.2/include/shareLib.h:138:2: warning: suggest not using #elif in traditional C
...snip
../alCaCommon.c: In function 'nextGroupChannel':
../alCaCommon.c:73: warning: traditional C rejects ISO C style function definitions
../alCaCommon.c: In function 'alCaCancel':
../alCaCommon.c:121: warning: traditional C rejects ISO C style function definitions
../alCaCommon.c: In function 'alSetNotConnected':
../alCaCommon.c:150: warning: traditional C rejects ISO C style function definitions
../alCaCommon.c: In function 'alPutGblAckT':
../alCaCommon.c:183: warning: traditional C rejects ISO C style function definitions
../alCaCommon.c: In function 'alProcessCA':
../alCaCommon.c:209: warning: traditional C rejects ISO C style function definitions
../alCaCommon.c: In function 'registerCA':
../alCaCommon.c:217: warning: traditional C rejects ISO C style function definitions
../alCaCommon.c:233: warning: traditional C rejects string constant concatenation
../alCaCommon.c:242: warning: traditional C rejects string constant concatenation
../alCaCommon.c: At top level:
../alCaCommon.c:278: warning: function declaration isn't a prototype
../alCaCommon.c:121: internal compiler error: Bus error
Please submit a full bug report,
with preprocessed source if appropriate.
See <URL:http://developer.apple.com/bugreporter> for instructions.
make[1]: *** [alCaCommon.o] Error 1
make: *** [install.darwin-ppc] Error 2
[kp1pc10:extensions/src/alh] bkolb% gcc -v
Using built-in specs.
Target: powerpc-apple-darwin8
Configured with: /private/var/tmp/gcc/gcc-5026.obj~19/src/configure --disable-checking --prefix=/usr --mandir=/share/man --enable-languages=c,objc,c++,obj-c++ --program-transform-name=/^[cg][^+.-]*$/s/$/-4.0/ --with-gxx-include-dir=/include/gcc/darwin/4.0/c++ --build=powerpc-apple-darwin8 --host=powerpc-apple-darwin8 --target=powerpc-apple-darwin8
Thread model: posix
gcc version 4.0.0 (Apple Computer, Inc. build 5026)
Any clue?
    Burkhard
I use gcc version 3.3 on MacOSX 10.4.5.Have you tried
sudo /usr/sbin/gcc_select 3.3
and run EPICS make?
Noboru Yamamoto
EPICS group/J-PARC control group
KEK, JAPAN
Problem building alh on Mac OSX Burkhard Kolb
Prev: Problem building alh on Mac OSX Burkhard Kolb
Next: Re: Problem building alh on Mac OSX Thomas Pelaia II
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
