Benjamin Franksen wrote: I have one question: the docs say that readback from devices for output records (for bumpless reboot) is done synchronously, blocking iocInit until all such readbacks have completed. There may be situations where this is the right aproach. However, there are others, where one would wish to have the readback to proceed asynchronously, for instance if there are a lot of such records on an IOC. If you have many of such records, iocInit may take a long time. Initializing the records synchronously was the easiest way to ensure that all initialized records have got their values before any record processes and can ask for that value. (This is something I do not want to give up.) I'll try to implement a more clever way to do this, initializing the records asyncronously ("in parallel") and then waiting in iocInit until all records have competed before the scan tasks start. If you send me some code example from your MultiCAN package, I will have a look at it.
There is a conceptional difference between the @init handler and PINI. The first is initialization of the record (called from init_record()), the second is initialization of the device (called from process()). Readback on startup is enabled if and only if an @init handler is defined (that reads the value). If you don't want a readback, don't define an @init handler. If you don't want to overwrite the value in the device, don't set PINI. I leave it to the user to decide if PINI after @init makes sense or not. Why should StreamDevice try to be smarter than the user? BTW: Maybe @init handlers do other stuff than readback, e.g. initializing the hardware. There is no simple way how StreamDevice can find out what @init actually does. Dirk -- Dr. Dirk Zimoch Swiss Light Source Paul Scherrer Institut Computing and Controls phone +41 56 310 5182 fax +41 56 310 4413
ANJ, 02 Sep 2010 |
![]() · Download · Search · IRMIS · Talk · Documents · Links · Licensing · |
