Greetings- snc/seq version 2.0.11 is now available on the SLAC ftp site:
http://www.slac.stanford.edu/comp/unix/package/epics/sequencer/
According to Andrew Johnson, "the build has been tested against versions
of Base going back to R3.14.7".
Additions to the "NOTESbyMRK" file since seq 2.0.10:
> When you run a standalone sequencer the -s option provides iocsh.
> If the -s option is not given no shell is started.
> For example
> ./sncProgram -s "user=mrkHost"
> epics>
> The iocsh shell provides a help command to see what commands are available.
> Version 2.0.11 contains the following changes:
> A bugfix in src/seq/seq_ca.c found by Stephanie Allison and Till Straumann.
> Moved the PV build configuration variables from configure/RELEASE to the new
> CONFIG_SITE file, and moved CONFIG_APP functionality into CONFIG. Also set
> CHECK_RELEASE to YES by default in configure/Makefile.
Please advise of any problems.
Mike
Michael P. Laznovsky mailto:[email protected]
Application Software Developer, CPE ofc: (650) 926-2924
Stanford Linear Accelerator Center, MS-46 fax: (650) 926-3515
2575 Sand Hill Road, Menlo Park CA 94025 USA http://www.slac.stanford.edu
RE: IOC shutdown signal(s) Al Honey
RE: IOC shutdown signal(s) Thompson, David H.
<2006>
2025
EPICS Training Course, Cambridge, England. July 2006 Philip Taylor
<2006>
2025
