At the KECK observatory we use serial-to-digital devices (Metrabyte,
DGH, hmm forgotten the others but there are version that are RS-232 or
RS-485) which are connected to terminal servers. The digital outputs
from those devices either pull the VME reset line low and/or connect to
digital input signals on VME boards from which interrupts can be
generated.
AH
-----Original Message-----
Sent: Monday, April 03, 2006 9:06 AM
To: Andrew Johnson; Rod Nussbaumer
Cc: [email protected]
Subject: RE: IOC shutdown signal(s)
I'm hoping that Dave Thompson will respond with information about the
"procServ" we use here.
However, in addition to that, which lets you do a ^X on the console, or
exit(), (and I've used that to create a reboot record as suggested by
Andrew) - I've created scripts called lxRestart and lxRestartDev that
kill the processes and restart them under a user we've created for the
purpose of running soft IOCs. My idea was that I did not want a process
needed by operations that couldn't be stopped or restarted by anybody
but me.
Pam.
> From: Andrew Johnson [mailto:[email protected]]
> Sent: Monday, April 03, 2006 2:57 PM
> To: Rod Nussbaumer
> Subject: Re: IOC shutdown signal(s)
> Rod Nussbaumer wrote:
> > I am trying to set up a Linux host running a soft IOC, where there
is a
> > coordinated system of start-stop-restart commands available for
> > maanaging the IOC as a system service. I would like to be able to
issue
> > a signal to the IOC to shut it down in a way that is at least as
> > graceful as typing 'exit' at the IOC shell. Which, if any, signal
does
> > this? Is there any reason a new IOC could not be immediately
started?
> > The EPICS database may change between runs. In fact, this is the
main
> > reason for performing the restart.
> There is no signal (as in "kill -HUP" type of signal) to restart an
IOC.
> You can create a subroutine record that calls exit() though and then
> use caput to do this (the softIoc binary that gets built by base
> includes such an exit subroutine already). Alternatively you could
wrap
> your IOC binary with a script to do the restart, and just kill the ioc
> process directly. We do something like this here at APS to ensure
that
> soft IOCs automatically restart themselves in the event of a crash,
> although we do have a restart limit counter to ensure they don't loop
> forever.
> - Andrew
> There is no S in exprexxo.
RE: IOC shutdown signal(s) Gurd, Pamela A.
seq 2.0.11 now available Laznovsky, Michael
<2006>
2025
RE: IOC shutdown signal(s) Thompson, David H.
<2006>
2025
