1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: Re: Ethernet/IP Device Support and CompactLogix
To: Carl Cork <[email protected]>
Cc: EPICS Tech-Talk <[email protected]>
Date: Thu, 06 Apr 2006 12:33:58 -0400
On Apr 6, 2006, at 12:17 , Carl Cork wrote:
According to CIP Protocol Ed. 2.2 (Dec 2005), C-5.2.6 String Encodings:
a SHORT_STRING consists of a 1-Byte character count followed by count
characters (1 byte per character). Therefore, the Product Name attribute
field should have a maximum length of 33 bytes.
John Dobbins wrote:
Kay,
Actually, it looks like there may be another interpretation. The product name is defined as (DeviceNet?) type SHORT_STRING. I don't know where this is defined but it looks like it may be: "a single byte length field and 'n' data bytes".
In which case the Product Name is being returned inside a longer field. The Product Name is less than 32 characters but the data field it is returned in is longer than 32 bytes.
EIP_check_interface() rejects the product name because is finds the length of the data returned >32, even though the string length is less than 32.
You're right in that the length check used the data package size, and the package contains BYTE length BYTE name[length]
So the actual name length is one less than the package byte count.
Then it's copied into a C char name[] with an added final '\0',
which adds another byte.
Strictly speaking, I need to check the length byte,
instead of silently expecting it to contain (package length-1).
OK, I'll do that.
Now where are we with CompactLogix?
What product name does it return?
How long is it? BTYE 51 + 51 characters?
Or does it return
  BYTE length=32
  char name[32]
  ... plus more junk to get a package of 52 bytes
-Kay
Re: Ethernet/IP Device Support and CompactLogix John Dobbins
Re: Ethernet/IP Device Support and CompactLogix Kay-Uwe Kasemir
Re: Ethernet/IP Device Support and CompactLogix Carl Cork
Prev: Re: Ethernet/IP Device Support and CompactLogix Carl Cork
Next: Re: Ethernet/IP Device Support and CompactLogix John Dobbins
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
ANJ, 02 Sep 2010 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
