1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: php epics module
To: [email protected]
Date: Fri, 05 May 2006 17:51:04 +0200
Hello,
I'd like to use the php epics module but I meet some difficulties. When I am trying to launch the test_ca_get_put.php example :
<?php
	#load external module
	dl("php_epics.so");
	#call function ca_get implemented in the php_epics.so module and display
	#the result
	$rt = ca_get("TEST:ai1");
	echo "Channel TEST:ai1 ".$rt;
	#in order to call ca_put function we want to pass a value as a parameter from
	#a text field
	echo "<FORM METHOD=GET ACTION=test_ca_get_put.php>\n";
	echo "Channel TEST:ai2 <INPUT TYPE=TEXT NAME=CHANNEL VALUE=".$_GET["CHANNEL"].">";
	echo "<INPUT TYPE=SUBMIT VALUE=Go>\n";
	echo "</FORM>";
	#call the function
	ca_put("TEST:ai2",$_GET["CHANNEL"]);
	#read and display the value
	echo "Channel TEST:ai2 ".ca_get("TEST:ai2");
	#Note: Channels "TEST:ai1","TEST:ai2" are running as soft channels on a PC
	#      on PSI network.
from a web browser, I have the following display :
*"Warning*: dl(): Unable to load dynamic library '/usr/local/lib/php/extensions/php_epics.so' - libCom.so: cannot open shared object file: No such file or directory in */var/www/html/ImmsData/test_ca_get_put.php* on line *3"
*although the path to php_epics.so is correct.*
*Does anybody know what's going on ?
Thanks
Christophe
Re: php epics module Andrew Johnson
Prev: Re: Power Monitoring John A. Priller
Next: Re: EDM Command Options Question John Dobbins
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Power Monitoring Jon Brinkmann
Next: Re: php epics module Andrew Johnson
