1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: php epics module
To: Christophe Moins <[email protected]>
Cc: [email protected]
Date: Fri, 05 May 2006 11:21:01 -0500
Christophe Moins wrote:
I'd like to use the php epics module but I meet some difficulties. When I am trying to launch the test_ca_get_put.php example :
<snip>
from a web browser, I have the following display :
*"Warning*: dl(): Unable to load dynamic library '/usr/local/lib/php/extensions/php_epics.so' - libCom.so: cannot open shared object file: No such file or directory in */var/www/html/ImmsData/test_ca_get_put.php* on line *3"
*although the path to php_epics.so is correct.*
*Does anybody know what's going on ?
Well the error message you're getting says "I can't load the php_epics.so library because it in turn needs to load libCom.so which I can't find."
Run 'ldd /usr/local/lib/php/extensions/php_epics.so' to find out where it's trying to get libCom.so from - it's part of EPICS Base so should be installed in your base/lib/<host-arch> directory, but if you didn't compile that php_epics.so file on the web server machine then it might not be present. In this case you should be able to fix it by copying libCom.so to the /usr/local/lib/php/extensions directory (you may also need libca.so in there as well).
- Andrew
There is no S in exprexxo.
php epics module Christophe Moins
Prev: Re: EDM Command Options Question John Dobbins
Next: MIPS epicsEventWaitWithTimeout(() Matt Rippa
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: php epics module Christophe Moins
Next: Re: EDM Command Options Question John Dobbins
