1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: Re: asynDriver / epicsTimer bug
To: TECHTALK <[email protected]>
Date: Wed, 31 May 2006 11:27:54 +0200
Hi all,
attached is a test program that can reproduce the problem. Since it uses sysClkRateGet(), it compiles only on vxWorks.
It calls pasynOctet->readRaw() once with pasynUser->timeout=1.1/sysClkRateGet() and once with pasynUser->timeout=1.0/sysClkRateGet().
In the first case, readRaw() returns asynTimeout, as expected. In the second case, readRaw() does not return.
I print the thread ID before calling readRaw(). When I do 'tt' on the thread ID, readRaw() suddenly returns asynTimeout. Very strange.
A Makefile is also attached. No records are required. Just set up a TCP server somewhere, call drvAsynIPPortConfigure and run:
readTimeoutTest "portname".
BTW: As long as readRaw() hangs, I could not open a channel access connection to records on that IOC and the dbior command hangs when trying to report drvAsyn.
I use asynDriver version 4-5, EPICS base R3.14.8, vxWorks 5.5 on MVME2300 (ppc604).
Dirk
Dirk Zimoch wrote:
Hi Marty, Jeff et al
When asynOctet->read() (or at least readRaw() of the TCP port driver) is called on vxWorks with pasynUser->timeout < 1/sysClkRateGet() [normally about 16 ms], the read call hangs and does never time out.
I think it is actually a problem with epicsTimer, which never expires for timeouts < 1/sysClkRateGet(). But I have not tested this.
I think, a timer should wait at least the specified amount of time, thus always round up to at least one tick.
Dirk
-- Dr. Dirk Zimoch Swiss Light Source Paul Scherrer Institut Computing and Controls phone +41 56 310 5182 fax +41 56 310 4413
#include <asynDriver.h>
#include <asynOctet.h>
#include <epicsThread.h>
#include <sysLib.h>
static char* asynStatusStr[] = {"Success", "Timeout", "Overflow", "Error"};
void readTimeoutTestHandleRequest(asynUser* pasynUser)
    asynInterface* pasynInterface;
    asynOctet* pasynOctet;
    void* pvtOctet;
    char buffer[1];
    asynStatus status;
    size_t received;
    int eomReason;
    printf ("readTimeoutTestHandleRequest, thread = %s %p\n",
        epicsThreadGetNameSelf(), epicsThreadGetIdSelf());
    pasynInterface = pasynUser->userPvt;
    pasynOctet =  pasynInterface->pinterface;
    pvtOctet = pasynInterface->drvPvt;
    pasynUser->timeout = 1.1 / sysClkRateGet();
    printf ("calling pasynOctet->readRaw() with %g seconds timeout\n",
        pasynUser->timeout);
    status = pasynOctet->readRaw(pvtOctet, pasynUser, buffer, 1,
        &received, &eomReason);
    printf ("pasynOctet->readRaw() returned status %s\n",
        asynStatusStr[status]);
    pasynUser->timeout = 1.0 / sysClkRateGet();
void readTimeoutTestTimeout(asynUser* pasynUser)
    printf ("pasynManager->queueRequest() timed out\n");
int readTimeoutTest(char * port, int addr)
    asynStatus status;
    asynUser* pasynUser;
    pasynUser = pasynManager->createAsynUser(readTimeoutTestHandleRequest,
        readTimeoutTestTimeout);
    if (pasynManager->connectDevice(pasynUser, port, addr) !=
        asynSuccess)
        printf ("No such device: %s,%d\n", port, addr);
        return ERROR;
    pasynInterface = pasynManager->findInterface(pasynUser,
        asynOctetType, TRUE);
    if (!pasynInterface)
        printf ("No asynOctet interface: %s,%d\n", port, addr);
        return ERROR;
    pasynUser->userPvt = pasynInterface;
    status = pasynManager->queueRequest(pasynUser,
        asynQueuePriorityHigh, 10.0);
    if (status != asynSuccess)
        printf ("pasynManager->queueRequest() failed: %s\n",
            pasynUser->errorMessage);
        return ERROR;
    return OK;
TOP=../..
include $(TOP)/configure/CONFIG
HOST_OPT = NO
PROD_vxWorks = asynApp
DBD  = asynApp.dbd
asynApp_DBD += base.dbd
PROD_SRCS += asynApp_registerRecordDeviceDriver.cpp
PROD_SRCS += readTimeoutTest.c
asynApp_DBD += drvAsynIPPort.dbd
PROD_LIBS += asyn
PROD_LIBS += $(EPICS_BASE_IOC_LIBS)
include $(TOP)/configure/RULES
Re: asynDriver / epicsTimer bug Eric Norum
asynDriver / epicsTimer bug Dirk Zimoch
Prev: about building ChannelArchiver for base3.14 Zhao Zhuo
Next: StreamDevice 2.1 released Dirk Zimoch
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Prev: Re: asynDriver / epicsTimer bug Benjamin Franksen
Next: Re: asynDriver / epicsTimer bug Eric Norum
ANJ, 02 Sep 2010 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
