1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: Re: asynDriver / epicsTimer bug
To: Dirk Zimoch <[email protected]>
Cc: TECHTALK <[email protected]>
Date: Wed, 31 May 2006 06:56:03 -0500
Can you try this with the current CVS head version of ASYN?  This latest version no longer uses EPICS timers -- we found that there were just too many problems trying to cancel I/O operations using a timer callback.
It would be good if you could confirm that this problem has gone away before we release ASYN 4-6.
On May 31, 2006, at 4:27 AM, Dirk Zimoch wrote:
Hi all,
attached is a test program that can reproduce the problem. Since it uses sysClkRateGet(), it compiles only on vxWorks.
It calls pasynOctet->readRaw() once with pasynUser->timeout=1.1/sysClkRateGet() and once with pasynUser->timeout=1.0/sysClkRateGet().
In the first case, readRaw() returns asynTimeout, as expected. In the second case, readRaw() does not return.
I print the thread ID before calling readRaw(). When I do 'tt' on the thread ID, readRaw() suddenly returns asynTimeout. Very strange.
A Makefile is also attached. No records are required. Just set up a TCP  server somewhere, call drvAsynIPPortConfigure  and run:
readTimeoutTest "portname".
BTW: As long as readRaw() hangs, I could not open a channel access connection to records on that IOC and the dbior command hangs when trying to report drvAsyn.
I use asynDriver version 4-5, EPICS base R3.14.8, vxWorks 5.5 on MVME2300 (ppc604).
Dirk
Dirk Zimoch wrote:
Hi Marty, Jeff et al
When asynOctet->read() (or at least readRaw() of the TCP port driver) is called on vxWorks with pasynUser->timeout < 1/sysClkRateGet() [normally about 16 ms], the read call hangs and does never time out.
I think it is actually a problem with epicsTimer, which never expires for timeouts < 1/sysClkRateGet(). But I have not tested this.
I think, a timer should wait at least the specified amount of time, thus always round up to at least one tick.
Dirk
Dr. Dirk Zimoch
Swiss Light Source
Paul Scherrer Institut
Computing and Controls
phone +41 56 310 5182
fax   +41 56 310 4413
#include <asynDriver.h>
#include <asynOctet.h>
#include <epicsThread.h>
#include <sysLib.h>
static char* asynStatusStr[] = {"Success", "Timeout", "Overflow", "Error"};
void readTimeoutTestHandleRequest(asynUser* pasynUser)
    asynInterface* pasynInterface;
    asynOctet* pasynOctet;
    void* pvtOctet;
    char buffer[1];
    asynStatus status;
    size_t received;
    int eomReason;
    printf ("readTimeoutTestHandleRequest, thread = %s %p\n",
        epicsThreadGetNameSelf(), epicsThreadGetIdSelf());
    pasynInterface = pasynUser->userPvt;
    pasynOctet =  pasynInterface->pinterface;
    pvtOctet = pasynInterface->drvPvt;
    pasynUser->timeout = 1.1 / sysClkRateGet();
    printf ("calling pasynOctet->readRaw() with %g seconds timeout\n",
        pasynUser->timeout);
    status = pasynOctet->readRaw(pvtOctet, pasynUser, buffer, 1,
        &received, &eomReason);
    printf ("pasynOctet->readRaw() returned status %s\n",
        asynStatusStr[status]);
    pasynUser->timeout = 1.0 / sysClkRateGet();
void readTimeoutTestTimeout(asynUser* pasynUser)
    printf ("pasynManager->queueRequest() timed out\n");
int readTimeoutTest(char * port, int addr)
    asynStatus status;
    asynUser* pasynUser;
    pasynUser = pasynManager->createAsynUser(readTimeoutTestHandleRequest,
        readTimeoutTestTimeout);
    if (pasynManager->connectDevice(pasynUser, port, addr) !=
        asynSuccess)
        printf ("No such device: %s,%d\n", port, addr);
        return ERROR;
    pasynInterface = pasynManager->findInterface(pasynUser,
        asynOctetType, TRUE);
    if (!pasynInterface)
        printf ("No asynOctet interface: %s,%d\n", port, addr);
        return ERROR;
    pasynUser->userPvt = pasynInterface;
    status = pasynManager->queueRequest(pasynUser,
        asynQueuePriorityHigh, 10.0);
    if (status != asynSuccess)
        printf ("pasynManager->queueRequest() failed: %s\n",
            pasynUser->errorMessage);
        return ERROR;
    return OK;
TOP=../..
include $(TOP)/configure/CONFIG
HOST_OPT = NO
PROD_vxWorks = asynApp
DBD  = asynApp.dbd
asynApp_DBD += base.dbd
PROD_SRCS += asynApp_registerRecordDeviceDriver.cpp
PROD_SRCS += readTimeoutTest.c
asynApp_DBD += drvAsynIPPort.dbd
PROD_LIBS += asyn
PROD_LIBS += $(EPICS_BASE_IOC_LIBS)
include $(TOP)/configure/RULES
Eric Norum <[email protected]>
Advanced Photon Source
Argonne National Laboratory
(630) 252-4793
Re: asynDriver / epicsTimer bug Dirk Zimoch
Prev: StreamDevice 2.1 released Dirk Zimoch
Next: Re: asynDriver / epicsTimer bug Eric Norum
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Prev: Re: asynDriver / epicsTimer bug Dirk Zimoch
Next: Re: asynDriver / epicsTimer bug Dirk Zimoch
ANJ, 02 Sep 2010 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
