1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: Re: asynDriver / epicsTimer bug
To: Eric Norum <[email protected]>
Cc: TECHTALK <[email protected]>
Date: Wed, 31 May 2006 17:33:34 +0200
Eric Norum wrote:
Can you try this with the current CVS head version of ASYN? This latest version no longer uses EPICS timers -- we found that there were just too many problems trying to cancel I/O operations using a timer callback.
It would be good if you could confirm that this problem has gone away before we release ASYN 4-6.
I tried the CVS version and it looks fine. It works with small timeouts, even with 0 timeout.
I have also tested it with StreamDevice. It works well and connection/reconnection is much faster than before.
Dirk
Dr. Dirk Zimoch
Swiss Light Source
Paul Scherrer Institut
Computing and Controls
phone +41 56 310 5182
fax   +41 56 310 4413
asynDriver / epicsTimer bug Dirk Zimoch
Re: asynDriver / epicsTimer bug Dirk Zimoch
Re: asynDriver / epicsTimer bug Eric Norum
Prev: DirectLogic PLC ethernet driver? Sue Witherspoon
Next: Re: DirectLogic PLC ethernet driver? Dirk Zimoch
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Prev: Re: asynDriver / epicsTimer bug Eric Norum
Next: Re: asynDriver / epicsTimer bug Eric Norum
ANJ, 02 Sep 2010 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
