Same here (understood what Eric understood).
This looks like a good case for using a genSub to me - that way you
can put each of the numbers into a different record if you have use for
more than one of them. We had similar cases on tech-talk not too long
ago.
Aloha,
Maren
On Fri, 2 Jun 2006, Eric Norum wrote:
The way I interpreted the original message is that they're interested in only
one of the three values in the string returned from the instrument, and so
wouldn't need to do anything tricky with custom conversion routines or string
calc records.
On Jun 2, 2006, at 7:18 AM, Dalesio, Leo `Bob` wrote:
Two options for this would be:
Write a driver that sends the commands to the Keithly and puts the values
in local variables.
Have the device support read the local variables
Have the startup file start the task that continuously reads the Keithley.
Put the task to sleep between reads for whatever rate you are trying to
acieve.
Otherwise, use a string Calc record - I am fairly certain that it offers
format statements for parsing strings from GPIB devices.
Bob
-----Original Message-----
Sent: Friday, June 02, 2006 4:39 AM
To: [email protected]
Subject: need help
Hi!
I am trying to communicate with Keithley 6485 pA to read the current.After
sending the command it provides current value and some other value
separated by comma.but i am only interested to store the current.
The response is like this:
-1.047791E-13A,+4.055828E+03,+0.000000E+00\r
How it can be done?
will i have to use any convert function?
i am attaching the code here
static struct gpibCmd gpibCmds[] = {
/* Param 0 */
{&DSET_AI,GPIBREAD,IB_Q_LOW,"CONF:CURR""\r""READ?""\r",0,0,20,0,0,0,NULL,NULL,"\r"}
Thanks
tanushyam
TANUSHYAM BHATTACHARJEE
SCIENTIFIC OFFICER
VARIABLE ENERGY CYCLOTRON CENTRE
1/AF BIDHANNAGAR ,SALTLAKE ,KOLKATA-64
email:[email protected]
Phone #23371230/31/32/33/34 Extn: 2304
Fax: 91 33 3346871
- RE: Keithley 6485, was: Re: need help Walters, M (Malcolm)
- RE: need help Dalesio, Leo `Bob`
- Re: need help Eric Norum
communications with Keithley 6485, was: Re: need help Maren Purves
Re: Motor.h file broken for C Ronald L. Sluiter
<2006>
2025
<2006>
2025
ANJ, 02 Sep 2010 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
IRMIS
Talk
Documents
Links
Licensing
