1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: RE: Keithley 6485, was: Re: need help
To: "TECHTALK Tech-Talk" <[email protected]>
Date: Mon, 5 Jun 2006 08:33:12 +0100
Personally I would use StreamDevice
http://epics.web.psi.ch/software/streamdevice/ with this you can specify
a format string and match the value you want. The other two values can
be thrown away or read into other records.
Malcolm
> -----Original Message-----
> From: Maren Purves [mailto:[email protected]]
> Sent: 02 June 2006 19:13
> To: Eric Norum
> Cc: Dalesio, Leo `Bob`; TECHTALK Tech-Talk
> Subject: Keithley 6485, was: Re: need help
> Same here (understood what Eric understood).
> This looks like a good case for using a genSub to me - that
> way you can put each of the numbers into a different record
> if you have use for more than one of them. We had similar
> cases on tech-talk not too long ago.
> Aloha,
> Maren
> On Fri, 2 Jun 2006, Eric Norum wrote:
> > The way I interpreted the original message is that they're
> interested
> > in only one of the three values in the string returned from the
> > instrument, and so wouldn't need to do anything tricky with custom
> > conversion routines or string calc records.
> > On Jun 2, 2006, at 7:18 AM, Dalesio, Leo `Bob` wrote:
> >> Two options for this would be:
> >> Write a driver that sends the commands to the Keithly and puts the
> >> values in local variables.
> >> Have the device support read the local variables Have the startup
> >> file start the task that continuously reads the Keithley.
> >> Put the task to sleep between reads for whatever rate you
> are trying
> >> to acieve.
> >> Otherwise, use a string Calc record - I am fairly certain that it
> >> offers format statements for parsing strings from GPIB devices.
> >> Bob
> >> From: [email protected] [mailto:[email protected]]
> >> Sent: Friday, June 02, 2006 4:39 AM
> >> To: [email protected]
> >> Subject: need help
> >> Hi!
> >> I am trying to communicate with Keithley 6485 pA to read the
> >> current.After sending the command it provides current
> value and some
> >> other value separated by comma.but i am only interested to
> store the current.
> >> The response is like this:
> >> -1.047791E-13A,+4.055828E+03,+0.000000E+00\r
> >> How it can be done?
> >> will i have to use any convert function?
> >> i am attaching the code here
> >> static struct gpibCmd gpibCmds[] = {
> >>     /* Param 0 */
> {&DSET_AI,GPIBREAD,IB_Q_LOW,"CONF:CURR""\r""READ?""\r",0,0,20,0,0,0,N
> >> ULL,NULL,"\r"}
> >> Thanks
> >> tanushyam
> >> TANUSHYAM BHATTACHARJEE
> >> SCIENTIFIC OFFICER
> >> VARIABLE ENERGY CYCLOTRON CENTRE
> >> 1/AF BIDHANNAGAR ,SALTLAKE ,KOLKATA-64 email:[email protected]
> >> Phone #23371230/31/32/33/34 Extn: 2304
> >> Fax: 91 33 3346871
Keithley 6485, was: Re: need help Maren Purves
Prev: Re: Thanks for help Steven Banks
Next: Scaling a waveform record Paul Joireman
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Prev: Keithley 6485, was: Re: need help Maren Purves
Next: Re: need help Eric Norum
ANJ, 02 Sep 2010 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
