I have some problems with Channel Access to get data from an ioc running on redhat9 kernel 2.4.20-8smp with epics version3.14.7. On the ioc shell side, I have the following message : CAS: request from 192.168.101.20:50482 => "bad resource ID" CAS: Request from 192.168.101.20:50482 => cmmd=12 cid=0xffffffff type=0 count=0 postsize=0 CAS: Request from 192.168.101.20:50482 => available=0x1 N=0 paddr=(nil) CAS: forcing disconnect from 192.168.101.20:50482 CAS: request from 192.168.101.20:50539 => "bad resource ID" CAS: Request from 192.168.101.20:50539 => cmmd=12 cid=0xffffffff type=0 count=0 postsize=0 CAS: Request from 192.168.101.20:50539 => available=0x1 N=0 paddr=(nil) CAS: forcing disconnect from 192.168.101.20:50539 Has someone ever met such a problem ? Thanks Christophe
ANJ, 02 Sep 2010 |
![]() · Download · Search · IRMIS · Talk · Documents · Links · Licensing · |
