Hello Christophe,
What architecture do the client and server run on? Are both the client and
server running EPICS R3.14.7?
Jeff
> -----Original Message-----
> From: Christophe Moins [mailto:[email protected]]
> Sent: Tuesday, June 20, 2006 12:17 AM
> To: [email protected]
> Subject: CA troubles
> Hello,
> I have some problems with Channel Access to get data from an ioc running
> on redhat9 kernel 2.4.20-8smp with epics version3.14.7.
> On the ioc shell side, I have the following message :
> CAS: request from 192.168.101.20:50482 => "bad resource ID"
> CAS: Request from 192.168.101.20:50482 => cmmd=12 cid=0xffffffff type=0
> count=0 postsize=0
> CAS: Request from 192.168.101.20:50482 => available=0x1 N=0
> paddr=(nil)
> CAS: forcing disconnect from 192.168.101.20:50482
> CAS: request from 192.168.101.20:50539 => "bad resource ID"
> CAS: Request from 192.168.101.20:50539 => cmmd=12 cid=0xffffffff type=0
> count=0 postsize=0
> CAS: Request from 192.168.101.20:50539 => available=0x1 N=0
> paddr=(nil)
> CAS: forcing disconnect from 192.168.101.20:50539
> Has someone ever met such a problem ?
> Thanks
> Christophe
- CA troubles Christophe Moins
VDCT survey results Shepherd, EL (Emma)
Question on supporting GPIB waveform acquisition from a variety of scopes Chestnut, Ronald P.
<2006>
2025
Eclipse reading list Andrew Johnson
<2006>
2025
