Eric, Here is what the code looks like right now: program snchygrometer %%#include <ctype.h> %%#include <stdlib.h> %%#include <stdio.h> %%char rob[10] ; char *roba; assign roba to "rawdata" ; monitor roba ; float ch1 ; float ch2 ; float ch3 ; float ch4 ; float ch5 ; assign ch1 to "PV1"; assign ch2 to "PV2"; assign ch3 to "PV3"; assign ch4 to "PV4"; assign ch5 to "PV5"; %%int v ; %%int z ; %%extern char *wa1 ; %%char *sign="+-" ; %{ when() { rob=&roba; /*i dont know how to do this & wont work w/ roba as just rob*/ v=rob[0]; /*Get first char from string*/ wa1=strpbrk(rob, "+-"); /*Break string at +-,rest is wa1*/ z=(float)wa1; /*convert string to float z*/ ss ss1 { state state1 { when ( v==1) { ch1 = z; pvPut(ch1); } state state2 } state state2 { when ( v==2) { ch2 = z; pvPut(ch2); } state state3 } state state3 { when ( v==3) { ch3 = z; pvPut(ch3); } state state4 } state state4 { when ( v==4) { ch4 = z; pvPut(ch4); } state state5 } state state5 { when ( v==5) { ch5 = z; pvPut(ch5); } state state1 } }
make[3]: Entering directory `/home/sysuser/epics3.14.8.2/hygrometerApp/hygrometerApp/src/O.linux-x86' /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -ansi -O3 -Wall -g -I. -I.. -I../../../include/os/Linux -I../../../include -I/home/sysuser/epics3.14.8.2/base-3.14.8.2/../modules/soft/seq-2.0.11/include/os/Linux -I/home/sysuser/epics3.14.8.2/base-3.14.8.2/../modules/soft/seq-2.0.11/include -I/home/sysuser/epics3.14.8.2/base-3.14.8.2/include/os/Linux -I/home/sysuser/epics3.14.8.2/base-3.14.8.2/include -I/home/sysuser/epics3.14.8.2/modules/soft/asyn/4-6/include/os/Linux -I/home/sysuser/epics3.14.8.2/modules/soft/asyn/4-6/include sncProgram.c ../sncExample.stt:35: warning: return type defaults to `int' ../sncExample.stt: In function `when': ../sncExample.stt:36: `roba' undeclared (first use in this function) ../sncExample.stt:36: (Each undeclared identifier is reported only once ../sncExample.stt:36: for each function it appears in.) ../sncExample.stt:39: pointer value used where a floating point value was expected make[3]: *** [sncProgram.o] Error 1 make[3]: Leaving directory `/home/sysuser/epics3.14.8.2/hygrometerApp/hygrometerApp/src/O.linux-x86' make[2]: *** [install.linux-x86] Error 2 make[2]: Leaving directory `/home/sysuser/epics3.14.8.2/hygrometerApp/hygrometerApp/src' make[1]: *** [src.install] Error 2 make[1]: Leaving directory `/home/sysuser/epics3.14.8.2/hygrometerApp/hygrometerApp' make: *** [hygrometerApp.install] Error 2 What we are wondering is, why does it think rob is defaulting to int, when we are setting it as char?? Obviously, there is something wrong with array vs pointer (this is what I have been telling to my students), but this seems to compile without any issues outside of EPICS (well, the original ones we started out did, anyway). On 6/29/06, Eric Norum <[email protected]> wrote:
ANJ, 02 Sep 2010 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
