On Jun 30, 2006, at 7:02 AM, Ernest L. Williams Jr. wrote: On Fri, 2006-06-30 at 10:21 +0200, Bruins, Stefan wrote: When I try to put on the ASYN-4.3 driver on a linux computer a MAKE command I get the error:
/opt/epicsbase3-14/bin/linux-x86/dbToRecordTypeH: error while loading shared libraries: libdbStaticHost.so: cannot open shared object file: No such file or directory
What am I doing wrong here?
Has your EPICS base been moved (renamed) or mangled after it was built?
Check that "/opt/epicsbase3-14/lib/linux-x86/libdbStaticHost.so" exists.
Then check that you have your LD_LIBRARY_PATH setup to point to the location of your EPICS shared libraries
You shouldn't have to deal with LD_LIBRARY_PATH issues if you leave the libraries where they were built.
Also -- not that this has anything to do with the problem mentioned above, but ASYN-4.3 is getting to be a rather old release.
-- Advanced Photon Source Argonne National Laboratory (630) 252-4793
- error while loading shared libraries Bruins, Stefan
- Re: error while loading shared libraries Ernest L. Williams Jr.
Lesson learned: LINR, LINEAR, SLOPE, R3.13, R3.14, breakpoint tables Kay-Uwe Kasemir
<2006>
2025
<2006>
2025
ANJ, 02 Sep 2010 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
IRMIS
Talk
Documents
Links
Licensing
