1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: Lesson learned: LINR, LINEAR, SLOPE, R3.13, R3.14, breakpoint tables
To: tech talk <[email protected]>
Date: Fri, 30 Jun 2006 12:19:38 -0400
Hi:
I spent some time yesterday debugging a previously unknown
application, and couldn't find any obvious hint about the issue
in the release notes or tech talk.
When you use breakpoint tables, you have to first
define the break point table.
Then, according to the R3.14.8 IOC Appl. Dev. Guide:
* Copy the menuConvert.dbd file from EPICS base
* Add definitions for new breakpoint tables to the end
That's what got us!
The symptom:
An application that worked fine under R3.13 suddenly
stopped honoring LINR=LINEAR, EGUL=..., EGUF=... conversions.
We spent hours trying to figure out why some driver/device support's
special() routine didn't get invoked,
and why ESLO always ended up at 1.
The reason:
That application's menuConvert.dbd, based on the R3.13 original,
started with "NO CONVERSION", "LINEAR", "typeKdegF", ...
But for R3.14, it has to be "NO CONVERSION", "SLOPE", "LINEAR", ...
So while "dbpr" always indicated that our records were
configured for "LINR=LINEAR", they were in fact set to
LINR==1, which the R3.14 EPICS base code considers to be SLOPE,
not LINEAR.
==> Beware about application-specific menuConvert files
when moving to R3.14.
Well, I guess you all knew this, but this way I can
find it the next time around by searching tech-talk...
-Kay
Re: Lesson learned: LINR, LINEAR, SLOPE, R3.13, R3.14, breakpoint tables Andrew Johnson
Prev: Re: error while loading shared libraries Eric Norum
Next: question about dbLoadTemplate() Liyu, Andrei
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Next: Re: Lesson learned: LINR, LINEAR, SLOPE, R3.13, R3.14, breakpoint tables Andrew Johnson
ANJ, 02 Sep 2010 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
