Standard way to use dbLoadTemplate()is
1. ***st.cmd***
cd $TOP
dbLoadTemplate( "db/Test.substitutions")
2. Test.substitutions has links to templates files
file db/Test1.template ...
file db/Test2.template ...
So Test.substitutions and templates (Test1.template and Test2.template)
files should be in the same directory (in this example top/db/ )
How can it be used if the files are in the different directories?
I found a way in vxWorks.
For example, Test.substitutions is in
/ade/epics/iocCommon/"IOCName"/Data
and Test.template is in /ade/epics/iocTop/R3.14.7/SystemX/R2-0/db. Then
1. st.cmd has
SubstitutionPath=malloc( 100)
sprintf SubstitutionPath, "/ade/epics/iocCommon/%s/Data",iocName
nfsMount nfsServer,SubstitutionPath,"/SubPath"
TemplatePath=malloc( 100)
sprintf TemplatePath, "/ade/epics/iocTop/R3.14.7/SystemX/R2-0/db"
nfsMount nfsServer, TemplatePath,"/TemPath"
cd "/SubPath"
dbLoadTemplate("Test.substitutions")
2. Test.substitutions file has
file TemPath/Test1.template ...
(!!! "file top/db/Test1.template ..." doesn't work)
It works. But that is spaghetti's way and I suppose it will not work in
Windows and Linux.
So question:
Has anyone done something similar (to have template and substitutions
files in different directories)?
Thanks, Andrei.
- Re: Presentations from the last collaboration meeting. Andrew Johnson
Lesson learned: LINR, LINEAR, SLOPE, R3.13, R3.14, breakpoint tables Kay-Uwe Kasemir
RE: question about dbLoadTemplate() Mark Rivers
<2006>
2025
RE: Driver for SBS IP-OPTOIO-8 Mark Rivers
<2006>
2025
