directions in the Makefile, and I seem to be one bit of directions short in either way. If I build it as a component of my application, then how do I run it? For this, I uncomment these lines in the Makefile ESG_SRCS += sncExample.stt ESG_LIBS += seq pv (my application is ESG) and get things to build, but then after I run st.cmd and am at the "epics>" prompt of iocsh, what command do I give to run the sequence? None of seq, sncExample, seqShow,... work. They just give me a "Command Not Found" message. "nm" verifies that the sncExample symbol is there, along with some related othes 0804c020 d seqChan U seq_delay U seq_delayInit U seqRegisterSequencerCommands U seqRegisterSequencerProgram 0804c0a0 d seqSS 0804c0c0 D sncExample 0804af54 T sncExampleRegistrar 0804a73c T _start 0804c060 d state_ss1 If I alter the Makefile and make it standalone, I get a complaint that there is no "main()" routine, as shown below. Where do I pick up a main() from? $ make make -C O.linux-x86 -f ../Makefile TOP=../../.. T_A=linux-x86 install make[1]: Entering directory `/mnt/disk1/p/epics/support/agilentsg/ESGApp/src/O.linux-x86' /usr/bin/g++ -o sncExample -L/p/epics/support/seq/lib/linux-x86/ -L/p/epics/v3_14_8_f2/lib/linux-x86/ -Wl,-rpath,/mnt/disk1/p/epics/support/agilentsg/lib/linux-x86 -Wl,-rpath,/p/epics/support/seq/lib/linux-x86 -Wl,-rpath,/p/epics/support/asyn/4-6/lib/linux-x86 -Wl,-rpath,/p/epics/v3_14_8_f2/lib/linux-x86 sncExample.o -lseq -lpv -lcas -lgdd -liocsh -lasHost -ldbStaticHost -lregistryIoc -lca -lCom /usr/lib/gcc-lib/i386-redhat-linux/3.2.3/../../../crt1.o(.text+0x18): In function `_start': : undefined reference to `main' collect2: ld returned 1 exit status make[1]: *** [sncExample] Error 1
ANJ, 02 Sep 2010 |
![]() · Download · Search · IRMIS · Talk · Documents · Links · Licensing · |
