1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: Re: Moxa N-Port, ASYN and IOC Exit
To: Emmanuel Mayssat <[email protected]>
Cc: John Dobbins <[email protected]>, EPICS Tech-Talk <[email protected]>
Date: Fri, 28 Jul 2006 16:22:38 -0400
You can verify this by using the monitoring capability of the moxa
device. If tcp/ip ports stay connected indefinitely after the ioc exits,
then you will have to find a way to explicitly close the sockets. While
this might be true for VxWorks, I doubt it is true under linux. So, also
take a look at the moxa time-out/stay-alive/etc. configuration options.
I also use (and highly recommend) the MOXA N-PORT 5600 and do see that
some small amount of time is required before the connection can be re-
established but the connections do eventually close (there is some moxa
configuration that affects this behavior, but I can't remember the
details).
John Sinclair
On Fri, 2006-07-28 at 11:38 -0700, Emmanuel Mayssat wrote:
> I believe the number of connections to those MOXA is limited to a small
> number.
> The MOXA must consider that the maximum number of connections is
> currently open. Hence, the telnet to port 23 or 80 or any other do not
> work.
> To close the connection/socket on exit, you have to modify your iocsh.
> There was a thread on how to do this not so long ago.
> Hope this help,
> E
> On Fri, 2006-07-28 at 14:26 -0400, John Dobbins wrote:
> > Dear All,
> > I am using a MOXA N-PORT 5600, EPICS R3.14.7, ASYN 4-2-1. I have 8 serial
> > devices connected to the N-Port. Device support is based on ASYN using
> > drvAsynIPPort. The IOC is a soft IOC running on Linux (SL3).
> > Sometimes when I restart the IOC by typing "exit" at the ioc command line the
> > MOXA will crash, by which I mean it will no longer respond on any of the ports
> > including the web server and telnet ports. The only way to recover the MOXA is
> > to cycle power.
> > I am wondering if anyone else has had a similar experience and what advice
> > people might have for understanding this.
> > Regards and thanks,
> > John Dobbins
> > Cornell Laboratory for Accelerator Sciences and Education
> > Cornell University
> > Ithaca, NY
Moxa N-Port, ASYN and IOC Exit John Dobbins
Re: Moxa N-Port, ASYN and IOC Exit Emmanuel Mayssat
Prev: Re: build multiple tops? Andrew Johnson
Next: RE: sequencer under linux questions Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Prev: Re: Moxa N-Port, ASYN and IOC Exit Emmanuel Mayssat
Next: sequencer under linux questions Dennis Nicklaus
ANJ, 02 Sep 2010 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
