I'm trying
out EPICS for the first time and trying to build it on Windows. After
seeing the posts about Visual Studio 8 (2005), I've switched to using Visual
Studio 7 (.NET 2003) and made the change to configure/RULES_BUILD as described
in the known issues.
With that
I've got everything to build and com.dll even installs itself
now.
However,
the next error I'm getting is:
make[4]: ..\\..\\..\\..\\bin\\win32-x86\\antelope.exe: Command not found make[4]: *** [parse.c] Error 127 make[4]: Leaving directory `/cygdrive/e/epics/base-3.14.8.2/src/toolsComm/flex/O .win32-x86' make[3]: *** [install.win32-x86] Error 2 make[3]: Leaving directory `/cygdrive/e/epics/base-3.14.8.2/src/toolsComm/flex' The odd
thing is that antelope.exe is built and sitting in bin\win32-x86 and it seems to
run OK. Also if I manually cd down into the O.win32-x86 directory
and run the command above it seems to run (although there's no obvious
output -- not sure if that's OK or not).
Can anyone
suggest what's wrong?
Doug
make is
GNU make 3.80 from cygwin
perl is
perl5.8.7 from cygwin
compiler
is VS.NET 2003 Pro
OS is
Windows XP SP2.
ANJ, 02 Sep 2010 |
![]() · Download · Search · IRMIS · Talk · Documents · Links · Licensing · |
