Hi, during build it copies exe and required dll and obj in bin as well as O.win32-x86 directory...i think you have to modify some files in configure to do it correctly under windows as follows 1.base-3.14.8.2\configure\RULES_BUILD line no 330 ifdef WIN32ifdef BORLAND @$(INSTALL_PRODUCT) -d -m 555 $<* $(INSTALL_BIN)else @$(INSTALL_PRODUCT) -d -m 555 $< $(INSTALL_BIN)endif endif 2.base-3.14.8.2\configure\os\CONFIG_SITE.win32-x86.win32-x86 to select proper compiler you may encounter some other problem in makeBaseApp.pl.but clear it first thnaks tanushyam > Windows.After seeing the posts about Visual Studio 8 (2005), I've > switched to using > Visual Studio 7 (.NET 2003) and made the change to > configure/RULES_BUILD as > described in the known issues. > > With that I've got everything to build and com.dll even installs > itself now. > > However, the next error I'm getting is: > > ..\\..\\..\\..\\bin\\win32-x86\\antelope.exe -l -d ../parse.y > make[4]: ..\\..\\..\\..\\bin\\win32-x86\\antelope.exe: Command not > foundmake[4]: *** [parse.c] Error 127 > make[4]: Leaving directory > `/cygdrive/e/epics/base-3.14.8.2/src/toolsComm/flex/O > .win32-x86' > make[3]: *** [install.win32-x86] Error 2 > make[3]: Leaving directory > `/cygdrive/e/epics/base-3.14.8.2/src/toolsComm/flex' > > > The odd thing i! s that an
ANJ, 02 Sep 2010 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
