1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: RE: Problem building base 3.14.8.2 on Win32
To: <[email protected]>
Date: Tue, 1 Aug 2006 00:15:31 -0700
Thanks Tanyshyam for the quick reply, but unfortunately I've already applied the fix to RULES_BUILD.  Without that the build fails at the point of copying the executables.
With that fix the executables are copied and the make runs on for a while but then it fails when it tries to execute antelope.exe.
I'll also attach more of the trace to give some more context to where the build is failing (doing a "make clean uninstall" and then "make" fails at the same point but with just a lot more compilation steps happening).
Doug
E:\epics\base-3.14.8.2>make
make -C configure install
make[1]: Entering directory `/cygdrive/e/epics/base-3.14.8.2/configure'
make -C O.win32-x86 -f ../Makefile TOP=../.. T_A=win32-x86 install
make[2]: Entering directory `/cygdrive/e/epics/base-3.14.8.2/configure/O.win32-x
86'
make[2]: Nothing to be done for `install'.
make[2]: Leaving directory `/cygdrive/e/epics/base-3.14.8.2/configure/O.win32-x8
6'
make[1]: Leaving directory `/cygdrive/e/epics/base-3.14.8.2/configure'
make -C src install
make[1]: Entering directory `/cygdrive/e/epics/base-3.14.8.2/src'
make -C makeBaseApp install
make[2]: Entering directory `/cygdrive/e/epics/base-3.14.8.2/src/makeBaseApp'
make -C O.win32-x86 -f ../Makefile TOP=../../.. T_A=win32-x86 install
make[3]: Entering directory `/cygdrive/e/epics/base-3.14.8.2/src/makeBaseApp/O.w
in32-x86'
make[3]: Nothing to be done for `install'.
make[3]: Leaving directory `/cygdrive/e/epics/base-3.14.8.2/src/makeBaseApp/O.wi
n32-x86'
make[2]: Leaving directory `/cygdrive/e/epics/base-3.14.8.2/src/makeBaseApp'
make -C makeBaseExt install
make[2]: Entering directory `/cygdrive/e/epics/base-3.14.8.2/src/makeBaseExt'
make[3]: Entering directory `/cygdrive/e/epics/base-3.14.8.2/src/makeBaseExt/O.w
in32-x86'
make[3]: Leaving directory `/cygdrive/e/epics/base-3.14.8.2/src/makeBaseExt/O.wi
n32-x86'
make[2]: Leaving directory `/cygdrive/e/epics/base-3.14.8.2/src/makeBaseExt'
make -C libCom install
make[2]: Entering directory `/cygdrive/e/epics/base-3.14.8.2/src/libCom'
make[3]: Entering directory `/cygdrive/e/epics/base-3.14.8.2/src/libCom/O.win32-
x86'
make[3]: Leaving directory `/cygdrive/e/epics/base-3.14.8.2/src/libCom/O.win32-x
86'
make[2]: Leaving directory `/cygdrive/e/epics/base-3.14.8.2/src/libCom'
make -C toolsComm install
make[2]: Entering directory `/cygdrive/e/epics/base-3.14.8.2/src/toolsComm'
make -C antelope install
make[3]: Entering directory `/cygdrive/e/epics/base-3.14.8.2/src/toolsComm/antel
ope'
make -C O.win32-x86 -f ../Makefile TOP=../../../.. T_A=win32-x86 install
make[4]: Entering directory `/cygdrive/e/epics/base-3.14.8.2/src/toolsComm/antel
ope/O.win32-x86'
make[4]: Nothing to be done for `install'.
make[4]: Leaving directory `/cygdrive/e/epics/base-3.14.8.2/src/toolsComm/antelo
pe/O.win32-x86'
make[3]: Leaving directory `/cygdrive/e/epics/base-3.14.8.2/src/toolsComm/antelo
pe'
make -C flex install
make[3]: Entering directory `/cygdrive/e/epics/base-3.14.8.2/src/toolsComm/flex'
make[4]: Entering directory `/cygdrive/e/epics/base-3.14.8.2/src/toolsComm/flex/
O.win32-x86'
perl ../../../../configure/tools/rm.pl -f parse.c y.tab.c
perl ../../../../configure/tools/rm.pl -f parse.h y.tab.h
..\\..\\..\\..\\bin\\win32-x86\\antelope.exe -l -d ../parse.y
make[4]: ..\\..\\..\\..\\bin\\win32-x86\\antelope.exe: Command not found
make[4]: *** [parse.c] Error 127
make[4]: Leaving directory `/cygdrive/e/epics/base-3.14.8.2/src/toolsComm/flex/O
.win32-x86'
make[3]: *** [install.win32-x86] Error 2
make[3]: Leaving directory `/cygdrive/e/epics/base-3.14.8.2/src/toolsComm/flex'
make[2]: *** [flex.install] Error 2
make[2]: Leaving directory `/cygdrive/e/epics/base-3.14.8.2/src/toolsComm'
make[1]: *** [toolsComm.install] Error 2
make[1]: Leaving directory `/cygdrive/e/epics/base-3.14.8.2/src'
make: *** [src.install] Error 2
Sent: Monday, July 31, 2006 11:34 PM
To: Douglas Pearson
Cc: [email protected]
Subject: Re: Problem building base 3.14.8.2 on Win32
during build it copies exe and required dll and obj in bin  as well as O.win32-x86 directory...i think
you have to modify some files in configure to do it correctly under windows as follows
1.base-3.14.8.2\configure\RULES_BUILD
line no 330
ifdef WIN32
ifdef BORLAND
@$(INSTALL_PRODUCT) -d -m 555 $<* $(INSTALL_BIN)
else
@$(INSTALL_PRODUCT) -d -m 555 $< $(INSTALL_BIN)
endif
endif
2.base-3.14.8.2\configure\os\CONFIG_SITE.win32-x86.win32-x86 to select proper compiler
you may encounter some other problem in makeBaseApp.pl.but clear it first
thnaks
 tanushyam
TANUSHYAM BHATTACHARJEE
SCIENTIFIC OFFICER
VARIABLE ENERGY CYCLOTRON CENTRE
1/AF BIDHANNAGAR ,SALTLAKE ,KOLKATA-64
email:[email protected]
Phone #23371230/31/32/33/34 Extn: 2304
Fax: 91 33 3346871
----- Original Message -----
Date: Tuesday, August 1, 2006 6:14 am
Subject: Problem building base 3.14.8.2 on Win32
> I'm trying out EPICS for the first time and trying to build it on
> Windows.After seeing the posts about Visual Studio 8 (2005), I've
> switched to using
> Visual Studio 7 (.NET 2003) and made the change to
> configure/RULES_BUILD as
> described in the known issues.
> With that I've got everything to build and com.dll even installs
> itself now.
> However, the next error I'm getting is:
> foundmake[4]: *** [parse.c] Error 127
> .win32-x86'
> The odd thing i! s that an
RE: Problem building base 3.14.8.2 on Win32 Douglas Pearson
Re: Problem building base 3.14.8.2 on Win32 btanu
Prev: Re: Problem building base 3.14.8.2 on Win32 btanu
Next: RE: How to change medm windows title + windows manager Rowland, J (James)
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Next: RE: Problem building base 3.14.8.2 on Win32 Douglas Pearson
ANJ, 02 Sep 2010 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
