I got a suggestion off-list to try
set MAKE_MODE=UNIX
(thanks Janet for that!).
This produces an interesting change. With that
flag set the make gets past this problem of launching
antelope.exe.
However it fails very shortly after with "/bin/sh.exe"
not found, like this:
make -C softIoc install
make[2]: Entering directory `/cygdrive/e/epics/base-3.14.8.2/src/softIoc' make -C O.win32-x86 -f ../Makefile TOP=../../.. T_A=win32-x86 install make[3]: Entering directory `/cygdrive/e/epics/base-3.14.8.2/src/softIoc/O.win32 -x86' make[3]: /bin/sh.exe: Command not found Cygwin does of course contain "sh.exe" and it's on the
path. Clearing the MAKE_MODE flag and issuing make again (w/o a clean)
doesn't have this problem and the make runs on until it's time to run the next
executable and it fails again.
So right now I'm setting this flag, running make, watch
it fail on sh.exe, clear the flag, run make again, watch it fail at a later
point on an executable and repeat.
I think doing this I'll eventually get to the end of
the build but I'm wondering if someone has a better solution as this is slow and
painful (and of course I can never rebuild)?
I'm using "make" from Cygwin and I assume that's the
root problem here.
E:\epics\base-3.14.8.2>make -version
GNU Make 3.80 Copyright (C) 2002 Free Software Foundation, Inc. Should I be using a different make or running it inside
a bash shell or something else?
Thanks a lot for everyone's help so far. I think
we're getting close here.
Doug
From: Douglas Pearson [mailto:[email protected]] Sent: Tuesday, August 01, 2006 12:16 AM To: [email protected] Subject: RE: Problem building base 3.14.8.2 on Win32 Thanks Tanyshyam for the quick reply, but
unfortunately I've already applied the fix to RULES_BUILD. Without
that the build fails at the point of copying the
executables.
With that fix the executables are copied and the make
runs on for a while but then it fails when it tries to execute
antelope.exe.
I'll also attach more of the trace to give some more
context to where the build is failing (doing a "make clean uninstall" and then
"make" fails at the same point but with just a lot more compilation steps
happening).
Doug
make -C configure install make[1]: Entering directory `/cygdrive/e/epics/base-3.14.8.2/configure' make -C O.win32-x86 -f ../Makefile TOP=../.. T_A=win32-x86 install make[2]: Entering directory `/cygdrive/e/epics/base-3.14.8.2/configure/O.win32-x 86' make[2]: Nothing to be done for `install'. make[2]: Leaving directory `/cygdrive/e/epics/base-3.14.8.2/configure/O.win32-x8 6' make[1]: Leaving directory `/cygdrive/e/epics/base-3.14.8.2/configure' make -C src install make[1]: Entering directory `/cygdrive/e/epics/base-3.14.8.2/src' make -C makeBaseApp install make[2]: Entering directory `/cygdrive/e/epics/base-3.14.8.2/src/makeBaseApp' make -C O.win32-x86 -f ../Makefile TOP=../../.. T_A=win32-x86 install make[3]: Entering directory `/cygdrive/e/epics/base-3.14.8.2/src/makeBaseApp/O.w in32-x86' make[3]: Nothing to be done for `install'. make[3]: Leaving directory `/cygdrive/e/epics/base-3.14.8.2/src/makeBaseApp/O.wi n32-x86' make[2]: Leaving directory `/cygdrive/e/epics/base-3.14.8.2/src/makeBaseApp' make -C makeBaseExt install make[2]: Entering directory `/cygdrive/e/epics/base-3.14.8.2/src/makeBaseExt' make -C O.win32-x86 -f ../Makefile TOP=../../.. T_A=win32-x86 install make[3]: Entering directory `/cygdrive/e/epics/base-3.14.8.2/src/makeBaseExt/O.w in32-x86' make[3]: Nothing to be done for `install'. make[3]: Leaving directory `/cygdrive/e/epics/base-3.14.8.2/src/makeBaseExt/O.wi n32-x86' make[2]: Leaving directory `/cygdrive/e/epics/base-3.14.8.2/src/makeBaseExt' make -C libCom install make[2]: Entering directory `/cygdrive/e/epics/base-3.14.8.2/src/libCom' make -C O.win32-x86 -f ../Makefile TOP=../../.. T_A=win32-x86 install make[3]: Entering directory `/cygdrive/e/epics/base-3.14.8.2/src/libCom/O.win32- x86' make[3]: Nothing to be done for `install'. make[3]: Leaving directory `/cygdrive/e/epics/base-3.14.8.2/src/libCom/O.win32-x 86' make[2]: Leaving directory `/cygdrive/e/epics/base-3.14.8.2/src/libCom' make -C toolsComm install make[2]: Entering directory `/cygdrive/e/epics/base-3.14.8.2/src/toolsComm' make -C antelope install make[3]: Entering directory `/cygdrive/e/epics/base-3.14.8.2/src/toolsComm/antel ope' make -C O.win32-x86 -f ../Makefile TOP=../../../.. T_A=win32-x86 install make[4]: Entering directory `/cygdrive/e/epics/base-3.14.8.2/src/toolsComm/antel ope/O.win32-x86' make[4]: Nothing to be done for `install'. make[4]: Leaving directory `/cygdrive/e/epics/base-3.14.8.2/src/toolsComm/antelo pe/O.win32-x86' make[3]: Leaving directory `/cygdrive/e/epics/base-3.14.8.2/src/toolsComm/antelo pe' make -C flex install make[3]: Entering directory `/cygdrive/e/epics/base-3.14.8.2/src/toolsComm/flex' make -C O.win32-x86 -f ../Makefile TOP=../../../..
make[4]: Entering directory `/cygdrive/e/epics/base-3.14.8.2/src/toolsComm/flex/ O.win32-x86' perl ../../../../configure/tools/rm.pl -f parse.c y.tab.c perl ../../../../configure/tools/rm.pl -f parse.h y.tab.h ..\\..\\..\\..\\bin\\win32-x86\\antelope.exe -l -d ../parse.y make[4]: ..\\..\\..\\..\\bin\\win32-x86\\antelope.exe: Command not found make[4]: *** [parse.c] Error 127 make[4]: Leaving directory `/cygdrive/e/epics/base-3.14.8.2/src/toolsComm/flex/O .win32-x86' make[3]: *** [install.win32-x86] Error 2 make[3]: Leaving directory `/cygdrive/e/epics/base-3.14.8.2/src/toolsComm/flex' make[2]: *** [flex.install] Error 2 make[2]: Leaving directory `/cygdrive/e/epics/base-3.14.8.2/src/toolsComm' make[1]: *** [toolsComm.install] Error 2 make[1]: Leaving directory `/cygdrive/e/epics/base-3.14.8.2/src' make: *** [src.install] Error 2 From: [email protected] [mailto:[email protected]] Sent: Monday, July 31, 2006 11:34 PM To: Douglas Pearson Cc: [email protected] Subject: Re: Problem building base 3.14.8.2 on Win32 Hi, during build it copies exe and required dll and obj in bin as well as O.win32-x86 directory...i think you have to modify some files in configure to do it correctly under windows as follows 1.base-3.14.8.2\configure\RULES_BUILD line no 330 ifdef WIN32ifdef BORLAND @$(INSTALL_PRODUCT) -d -m 555 $<* $(INSTALL_BIN)else @$(INSTALL_PRODUCT) -d -m 555 $< $(INSTALL_BIN)endif endif 2.base-3.14.8.2\configure\os\CONFIG_SITE.win32-x86.win32-x86 to select proper compiler you may encounter some other problem in makeBaseApp.pl.but clear it first thnaks tanushyam > Windows.After seeing the posts about Visual Studio 8 (2005), I've > switched to using > Visual Studio 7 (.NET 2003) and made the change to > configure/RULES_BUILD as > described in the known issues. > > With that I've got everything to build and com.dll even installs > itself now. > > However, the next error I'm getting is: > > ..\\..\\..\\..\\bin\\win32-x86\\antelope.exe -l -d ../parse.y > make[4]: ..\\..\\..\\..\\bin\\win32-x86\\antelope.exe: Command not > foundmake[4]: *** [parse.c] Error 127 > make[4]: Leaving directory > `/cygdrive/e/epics/base-3.14.8.2/src/toolsComm/flex/O > .win32-x86' > make[3]: *** [install.win32-x86] Error 2 > make[3]: Leaving directory > `/cygdrive/e/epics/base-3.14.8.2/src/toolsComm/flex' > > > The odd thing i! s that an
ANJ, 02 Sep 2010 |
![]() · Search · EPICS V4 · IRMIS · Talk · Bugs · Documents · Links · Licensing · |
