Hi Tim,
> > I see the EPID record producing a value that should be
> added to the ao
> > record's VAL field, implying the ao record should have
> OIF=Incremntal.
> > But with the EPID record putting OVAL into what's pointed
> to by OUTL
> > (ie the ao
> > record) I'd expect to have OMSL=supervisory in the ao record.
> Hang in there and see what happens as the controlled value
> responds to the new output value. With KP!=0 and KI==KD==0,
> you should see ERR=VAL-CVAL, and
> OVAL=KP*ERR. If not, do a "dbpr" on the record and send
> that. There might be some control field we're not thinking
> about with an unexpected value.
ERR is calculated correctly and OVAL contains the value == KP * ERR.
But this value now in OVAL is one that I would want to add to the VAL field in the ao record pointed to by OUTL (which in my case writes to a magnet power supply). Is it up then to the database designer to perform an OVAL + ao.VAL calculation and get the
result into ao.VAL?
Damien
- Re: looking for OSI version of epid record Andrew Johnson
Re: Dev Asyn and Cygwin/Win IOCs , Modbus and scheduling. Pete Jemian
<2006>
2025
Re: looking for OSI version of epid record Tim Mooney
<2006>
2025
