LYNCH, Damien wrote:
I see the EPID record producing a value that should be added to
the ao record's VAL field, implying the ao record should have
OIF=Incremntal. But with the EPID record putting OVAL into what's
pointed to by OUTL (ie the ao record) I'd expect to have
OMSL=supervisory in the ao record.
Hang in there and see what happens as the controlled value responds
to the new output value. With KP!=0 and KI==KD==0, you should see
ERR=VAL-CVAL, and OVAL=KP*ERR. If not, do a "dbpr" on the record
and send that. There might be some control field we're not
thinking about with an unexpected value.
ERR is calculated correctly and OVAL contains the value == KP * ERR.
But this value now in OVAL is one that I would want to add to the VAL
field in the ao record pointed to by OUTL (which in my case writes to
a magnet power supply). Is it up then to the database designer to
perform an OVAL + ao.VAL calculation and get the result into ao.VAL?
Damien has a point -- do the EPID record authors realise that the AO
record only looks at OIF and performs the required integration when
OMSL=Supervisory and the delta is being fetched through DOL? The
integration is implemented in fetch_value() which is only called if
((pao->dol.type != CONSTANT) && (pao->omsl == menuOmslclosed_loop)),
thus if DOL is not set and a value is poked straight into the AO's VAL
field using the EPID.OUTL link, no integration will take place.
This behaviour of the AO record was probably designed for the old PID
record which expected you to use DOL with OIF, and is not something we
can change now.
- Andrew
There is considerable overlap between the intelligence
of the smartest bears and the dumbest tourists.
-- Yosemite National Park Ranger
- Re: looking for OSI version of epid record Andrew Johnson
- Re: looking for OSI version of epid record Tim Mooney
- RE: looking for OSI version of epid record LYNCH, Damien
<2006>
2025
<2006>
2025
ANJ, 02 Sep 2010 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
IRMIS
Talk
Documents
Links
Licensing
