1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Setting option flags for building system libraries
To: <[email protected]>
Date: Wed, 23 Aug 2006 09:40:58 -0500
OK, it seems empty to me, and I don't think it should be, should it?
David Dudley
>>> Andrew Johnson <[email protected]> 08/23/06 9:14 AM >>>
David Dudley wrote:
> Would that account for the inability to read data from any of the
> defined channels?
That depends how you're trying to read that data - if via CA then yes it
might be related to that issue.
> 'dbl' lists the channels, and 'dbnr' gives counts of the channel
> types, but I can't access any data from the records.
You should be able to use 'dbpr <recordname>, <level>' to see the record
field values (level goes from 0 to 4) and watch them changing, which
will prove that the database scanning is working.
Please cut/paste the output from 'casr 2' which may give some more clues
with the CA problem.
>> The build works without error now, building the .so files with no
>> problem on 3.14.8.2, but can't pass the RTEMS or libCom/test
>> directories on the CVS download.  Haven't worked on that problem
>> yet....
It shouldn't be trying to actually compile anything under src/RTEMS
unless you've told the build system that netbsd-x86 is a valid
cross-compiler host for the RTEMS platform (which it probably isn't).
The libCom/test area won't build from the CVS trunk at the moment,
although it should do from the R3.14 branch snapshot.
- Andrew
There is considerable overlap between the intelligence
of the smartest bears and the dumbest tourists.
   -- Yosemite National Park Ranger
Attachment: myexample.log
Description: Binary data
BEGIN:VCARD
VERSION:2.1
X-GWTYPE:USER
FN:David Dudley
TEL;WORK:880-3740
ORG:;MIS
TEL;PREF;FAX:880-3741
EMAIL;WORK;PREF;NGW:[email protected]
N:Dudley;David
END:VCARD
Prev: MAXv Multi-Axis Motion Controller in use? Martin Heiniger
Next: Re: MAXv Multi-Axis Motion Controller in use? Kurt Goetze
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Setting option flags for building system libraries Andrew Johnson
Next: EPICS on NetBSD David Dudley
