1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: MAXv Multi-Axis Motion Controller in use?
To: Martin Heiniger <[email protected]>
Cc: TECHTALK <[email protected]>
Date: Wed, 23 Aug 2006 10:03:19 -0500
Hi Martin,
We have recently installed several MAXv cards into the sector 30 beamline
here at the APS. In one crate there is a mix of VME58 and MAXv boards.
In another there are only MAXv boards (6). In all cases the channels are set
up to run steppers, with several channels having encoder support enabled.
It is nice to be able to select encoder support on a channel by channel basis,
with a small change to a setup line in the boot file. So far the MAXv boards
are performing well, and we are planning to add them to other beamlines as
needed. We are running EPICS 3.14.7/synApps_5.1.1.
Kurt
Kurt Goetze
APS/AES/Beamline Controls
Martin Heiniger wrote:
Dear all
do you have a "MAXv Multi-Axis Motion Controller"* from Pro-Dex (OMS) in use? What is your experience?
I have seen the 2 entries from Ronald L. Sluiter and Jens Eden in the Tech-Talk archive.
Thanks for any feedback and best regards,
Martin
*) http://www.omsmotion.com/product_detail.php?prodid=8
MAXv Multi-Axis Motion Controller in use? Martin Heiniger
Prev: Re: Setting option flags for building system libraries David Dudley
Next: Any EPICS support for ICS 145? Steve Lewis
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: MAXv Multi-Axis Motion Controller in use? Martin Heiniger
Next: Re: MAXv Multi-Axis Motion Controller in use? Jens Eden
