1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: NetBSD: implementation of"osiSockDiscoverInterfaceAddresses()"
To: "'David Dudley'" <[email protected]>, <[email protected]>
Date: Thu, 24 Aug 2006 09:46:28 -0600
David,
Currently we have needed only these two versions.
libCom/osi/os/default/osdNetIntf.c
libCom/osi/os/win32/osdNetIntf.c
Currently all of the UNIX systems have found the default version to be
sufficient after allowing for some small os dependent variations in the
implementation of ifreq_size().
> On NetBSD, this function returns information that is "inconsistent" with
> Linux, I believe.
As I understand it Darwin (MAC OSX) is working fine with the default
osdNetIntf.c but it does need the more advanced implementation of
ifreq_size(). Be careful to have a look at the two variants of ifreq_size()
and make certain that a proper implementation is selected for NetBSD. If
ifreq_size() was wrong you might see complete garbage in the returned
structures.
This is the default:
epics\base\src\libCom\osi\os\alpha\osdSock.h(70):
#define ifreq_size(pifreq) (sizeof(pifreq->ifr_name))
Here is Darwin (probably the closest relative of NetBSD supported so far):
epics\base\src\libCom\osi\os\Darwin\osdSock.h(80):
#define ifreq_size(pifreq) ((pifreq)->ifr_addr.sa_len +
sizeof((pifreq)->ifr_name))
Linux:
epics\base\src\libCom\osi\os\Linux\osdSock.h(93):
Nevertheless, the source is organized so that you could easily provide an
osdNetIntf.c override in libCom/osi/os/NetBSD based on getifaddrs should
that prove to be necessary.
An implementation based on getifaddrs might be useful but perhaps not yet a
portability bullet as it is not in, for example, my latest vxWorks at hand
(vxWorks 5.4) nor in http://www.opengroup.org/pubs/online/7908799/.
Jeff
NetBSD: implementation of "osiSockDiscoverInterfaceAddresses()" David Dudley
Prev: Re: ezca and ENUM D. Peter Siddons
Next: Re: VME Bus Error handling on MVME3100 and 6100 boards Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: NetBSD: implementation of "osiSockDiscoverInterfaceAddresses()" David Dudley
Next: New Technology Alert: X-Ray-based Ultra-high Density Optical Memory (X-ROM) X-ROM, Inc.
