I personally would see it as a problem, because the EE interrupt is maskable. It's not trivial to write an exception handler that can nest properly such that if an interrupt service routine receives a Target- Abort from a PCI device it will immediately halt and abort the ISR rather than continuing on to completion and only then running the Target-Abort interrupt handler. If all you have is an interrupt, your ISRs probably ought to check with the Tempe chip that they're not getting VME bus errors before relying on the data they've just read (at least if the value they read back was all-1s). For the MVME6100, I am more concerned with the I'm not sure I understand your question. The "all-1s read data" I was talking about is the data that is returned if you do a programmed read cycle to the VMEbus that ends in a Bus Error. If the Bus Error occurs during a DMA operation using one of the DMA controllers in the Tempe chip then the DMA will be stopped immediately instead, since the controller is inside the Tempe and can see the Bus Error status. We have one application that could be optimied by the PCI bandwidth that MVME61000 offers ( 800 MHZ). Also, I am still not sure about the "MBLT" transfer of the VME backplane, whih was posted at http://www.aps.anl.gov/epics/tech-talk/2006/msg00888.php. I assumed it was limited by the capability of the DMA controller instead of the bus speed because I assume a simple test could be done easily by using two MVME6100s on a VME320 crate. Perhaps Till can verify this ?? The Tempe's DMA controllers are most likely to be limited by the speed of the VMEbus when doing MBLT cycles; the maximum data transfer rate you can get using MBLT is 80MB/s according to the VITA FAQ at http://www.vita.com/vmefaq.html#anchor419155 whereas the PCI/X bus on the MVME6100 can run faster than that. If you have a VME320 backplane and both boards are capable of 2eSST then your bottleneck might not be the VMEbus, but I don't know the answer to that question. Andrew Johnson wrote: > Anyone interested in MicroTCA to replace the now aging VMEbus? The VMEbus was first announced in 1981 - that's 25 years ago, which is what makes it aging as far as basic technology goes. I'm not saying its not still capable of doing the job, but the basic assumptions that the bus was designed around are starting to be seriously invalidated and for new facilities such as the ILC I would carefully examine alternative busses such as MicroTCA. - Andrew -- There is considerable overlap between the intelligence of the smartest bears and the dumbest tourists. -- Yosemite National Park Ranger
ANJ, 02 Sep 2010 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
