Very interesting information. Thanks a lot. I was told
that on the mvme6100, "MBLT performance is similar to
what the universe's". However, I do not really have any
experience on the mvme6100 yet. Thus, the above statement
could be wrong. I would appreciate if any experienced
expert on the mvme6100 can verify this statement.
Kate
Andrew Johnson wrote:
A major warning for anyone who is considering buying these recent
Motorola VME boards; I just discovered the following information in
the User Manual for the "Tempe" Tsi148 PCI/X-to-VME Bus Bridge chip
that they both use:
2.3.5 VMEbus Exception Handling
When a VMEbus transfer initiated by the VME Master does not complete
successfully, the status is saved in the VMEbus exception registers.
The exception registers are updated when a transaction is terminated
with a bus error, or a 2eVME or 2eSST transfer is terminated with a
slave termination.
When the VME Master encounters one of these conditions, any write
data in the buffers is removed (flushed). If the transaction was a
VMEbus read, the VME Master completes the Linkage Module command by
filling the buffer with a data pattern of all ones.
Tip: The interrupt controller can be programmed to generate an
interrupt when the exception registers are updated.
Elsewhere, it also says
The Tsi148 PCI Target never terminates a transaction with a
Target-abort
and
SIGTA (Signalled Target Abort): The Tsi148 does not generate a target
abort, therefore this bit is hard-wired to a logic 0.
For those of you who do not know much about the PCI bus, a Target
Abort is the PCI equivalent of a VME Bus Error - it terminates the
current read or write operation with an error condition and can be
made to cause the processor to take a Machine Check Exception.
VxWorks responds to this exception by suspending the currently
executing task.
The Universe-2 PCI-to-VME Bridge chip that is used on the MVME2100,
2700, 5100 and 5500 boards is able to generate a Target Abort when a
VMEbus read cycle terminates with a Bus Error. Although the BSPs
shipped by Wind River for these boards does not actually make use of
this capability, it is possible to modify them to get the Universe-2
to generate a Target Abort and hence a Machine Check Exception
whenever a bus error occurs, thus trapping any VME bus errors at the
moment they occur (for read cycles at least) and suspending the
relevent task at the point where the bus error occurred. I have
published BSP patches to do this for all of the boards we use here at
the APS, and I believe that many sites are using these modifications.
This behaviour is not possible with the Tempe chip - VME read cycles
that terminate with a Bus Error just return 0xFFFF values (all one
bits), and by default there is no indication that anything unusual
happened. It is possible to enable the VME Exception interrupt, which
will eventually be serviced by the processor and most of the time
would allow the BSP to suspend the correct task (assuming that the Bus
Error wasn't caused by an Interrupt Service Routine), but that
interrupt could be delayed for quite a long time by other pending
interrupts.
The only sure-fire way around this problem is to check the Tempe
chip's VMEbus Exception Attributes Register after every write
operation and every read that returns an all-1s bit pattern - clearly
not something conducive to good I/O performance, and not compatible
with any existing EPICS drivers.
As a result of the above, I would recommend that EPICS users avoid any
VME CPU board that uses the Tundra Tsi148 (Tempe) chip, and explain to
your Motorola sales representative why you are doing so.
- Andrew
- Re: VME Bus Error handling on MVME3100 and 6100 boards Andrew Johnson
- Re: VME Bus Error handling on MVME3100 and 6100 boards Till Straumann
- VME Bus Error handling on MVME3100 and 6100 boards Andrew Johnson
<2006>
2025
<2006>
2025
ANJ, 02 Sep 2010 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
IRMIS
Talk
Documents
Links
Licensing
