1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: VME Bus Error handling on MVME3100 and MVME6100 boards
To: Kate Feng <[email protected]>
Cc: [email protected]
Date: Tue, 29 Aug 2006 09:18:50 -0500
Kate Feng wrote:
Andrew Johnson wrote:
This doesn't mean that the existing drivers won't work; the vast
majority of the time they will be fine.  They will not be robust in the
presence of unexpected bus errors though.
And this problem rises only if the mvme6100 is used as a system controller. It will be fine if it's used a non system controller.
No, that is incorrect. The problem relates to the onboard interface between the CPU, its local PCI bus and the PCI to VME bridge chip; it is not at all related to whether the VME interface chip is acting as the VMEbus system controller or not.
- Andrew
There is considerable overlap between the intelligence of the smartest
bears and the dumbest tourists -- Yosemite National Park Ranger
Re: VME Bus Error handling on MVME3100 and MVME6100 boards Kate Feng
Re: VME Bus Error handling on MVME3100 and MVME6100 boards Andrew Johnson
Prev: Re: VME Bus Error handling on MVME3100 and MVME6100 boards Kate Feng
Next: RE: VME Bus Error handling on MVME3100 and MVME6100 boards Thompson, David H.
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: VME Bus Error handling on MVME3100 and MVME6100 boards Kate Feng
