1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: VME Bus Error handling on MVME3100 and MVME6100 boards
Cc: [email protected]
Date: Tue, 29 Aug 2006 21:19:00 -0400
Andrew Johnson wrote:
> >>This doesn't mean that the existing drivers won't work; the vast
> >>majority of the time they will be fine.  They will not be robust in the
> >>presence of unexpected bus errors though.
> > And this problem rises only if the mvme6100 is used as a
> > system controller.   It will be fine if it's used a non system
> > controller.
> No, that is incorrect.  The problem relates to the onboard interface
> between the CPU, its local PCI bus and the PCI to VME bridge chip; it is
> not at all related to whether the VME interface chip is acting as the
> VMEbus system controller or not.
I meant if one use mvme5500 as the system controller, and mvme6100 as a
2nd CPU.  In this case, mvme5500 is a VME master.  In your message :
http://www.aps.anl.gov/epics/tech-talk/2006/msg00887.php
It stated that "If the transaction was a VMEbus read, the VME Master
completes the Linkage Module command by
filling the buffer with a data pattern of all ones. "  This only applies
if the master CPU used the Tsi148 chip.
I am sorry, but I had trouble in obtaining the document for the Tsi148.
I had E-mail them since last week.
Kate
> - Andrew
> There is considerable overlap between the intelligence of the smartest
> bears and the dumbest tourists -- Yosemite National Park Ranger
Re: VME Bus Error handling on MVME3100 and MVME6100 boards Kate Feng
Re: VME Bus Error handling on MVME3100 and MVME6100 boards Andrew Johnson
Prev: RE: VME Bus Error handling on MVME3100 and MVME6100 boards Thompson, David H.
Next: Re: VME Bus Error handling on MVME3100 and MVME6100 boards Kate Feng
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: VME Bus Error handling on MVME3100 and MVME6100 boards Andrew Johnson
