1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: NetBSD Port
To: tech talk <[email protected]>
Date: Thu, 31 Aug 2006 16:19:46 -0400
On Aug 31, 2006, at 16:05 , David Dudley wrote:
OK, that tells me what I needed to know.
When I run the excas program on the netBSD machine, I get a message saying the server isn't attched to a network. Looks like I haven't got the dependent code quite right. I'll correct it now that I know what doesn't work.
I think you have to find the code that queries the OS for its network interfaces and their IP addresses. I can only provide the outside hint that you usually get that message when you really have no network card. On some systems, one can then try something like EPICS_CAS_INTF_ADDR_LIST=127.0.0.1 excas & to force use of the loopback device.
Note that unfortunately there are two CA servers in EPICS:
The one under base/src/cas (used by excas)
and the one under base/src/rsrv (used by the IOC).
I hope that once you figure out how to fix one,
you'll also know how to fix the other for netbsd.
-Kay
RE: NetBSD Port Jeff Hill
Re: NetBSD Port David Dudley
Prev: Re: NetBSD Port David Dudley
Next: Re: Fedora Core 6 to drop OpenMotif Kay-Uwe Kasemir
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: RE: NetBSD Port Jeff Hill
