> Note that unfortunately there are two CA servers in EPICS:
> The one under base/src/cas (used by excas)
> and the one under base/src/rsrv (used by the IOC).
> I hope that once you figure out how to fix one,
> you'll also know how to fix the other for netbsd.
Nevertheless, both of them rely on the same code snippet for default
initialization of the client and server address lists.
See the definition of ifreq_size for your OS. This is in
src/libCom/osi/os/XXXX/osdSock.h. We have only two versions of ifreq_size
conforming to the two different versions of this particular API that we have
seen.
Version for newer systems (probably originating from NetBSD):
#define ifreq_size(pifreq) (pifreq->ifr_addr.sa_len +
sizeof(pifreq->ifr_name))
Version for older systems:
#define ifreq_size(pifreq) (sizeof(pifreq->ifr_name))
If that doesn't work one might also replace the complete implementation in
src/libCom/osi/os/default/osdNetIntf.c with something else, but that level
of effort hopefully isn't necessary for NetBSD as Darwin is already working
with the more complex version of ifreq_size.
The server's address list can be seen if one types "casr 100" into the IOC's
command line.
Jeff
- Re: NetBSD Port Kay-Uwe Kasemir
Re: Fedora Core 6 to drop OpenMotif Kay-Uwe Kasemir
Re: NetBSD Port David Dudley
<2006>
2025
<2006>
2025
