Just a strange question, but I've noticed a tendency of all the source files to not have any comments (or very few) in them regarding what they do. I think a lot of it relates to the personal coding style of the original author(s) of EPICS Base. If you look at code from other people such as device support modules you'll see more comments. I get so busy with the multiple things I have to do, that if I don't comment the hell out of what I write, I might have to spend quite a bit of time decoding what I was doing before I needed to switch. Personally I'm in favor of including comments where they contribute to understanding what the code is trying to accomplish or as a reminder that there's something going on here which might not be immediately obvious. I also try to choose routine and variable names that are self exdplanatory, since that reduces the number of comments that are needed (please don't try and use Hungarian notation in names, even the original 'sensible' version). I don't think we're likely to remove any comments from the code you submit so don't worry about including comments that you feel are useful. - Andrew -- There is considerable overlap between the intelligence of the smartest bears and the dumbest tourists -- Yosemite National Park Ranger
ANJ, 02 Sep 2010 |
![]() · Download · Search · IRMIS · Talk · Documents · Links · Licensing · |
