1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: RE: EPICS source Documentation - Bloviation inside - don't open unless you want to waste the time
To: "David Dudley" <[email protected]>, <[email protected]>
Date: Fri, 8 Sep 2006 09:45:13 -0700
As the question must not be serious -
I'll state the obvious......
Code always tells the truth. Comments sometimes do not.
Documentation says how to use it.
Reading the code tells you how to modify it.
It is good practice for the comments to at least get you to the modules and subroutine that you are looking for. Once inside - you get what you get.
Personally, I write comments for me - I have a short memory.
There are very talented programmers that have done a lot of the base code, that do not trust anything but the code. They would read the code regardless of the presence of comments. They obviously don't need comments.
RE: EPICS source Documentation - Bloviation inside - don't open unless you want to waste the time Gurd, Pamela A.
EPICS source Documentation David Dudley
Prev: Re: EPICS source Documentation Kay-Uwe Kasemir
Next: Re: EPICS source Documentation Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Next: RE: EPICS source Documentation - Bloviation inside - don't open unless you want to waste the time Gurd, Pamela A.
ANJ, 02 Sep 2010 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
