1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: EPICS: Visualization
To: David Dudley <[email protected]>, [email protected]
Date: Fri, 8 Sep 2006 17:49:29 -0500 (CDT)
You can do this in two ways with medm ... an animated gif which has a process variable attached to it to indicate which frame to display ... OR ... do your own animation using overlayed objects and the visibility modifier.
If you launch the Virtual LINAC test application, you will see an interesting animation if you overheat the cathode ... tehehehe
   Ned
>So far, I have medm and edm built on my Linux system for displaying graphic data.
>Question:
>I don't see anything that allows me any type of 'animation' stuff (like rotations, scaling, active movements, ...)
>Does either medm or edm allow for this?
>David Dudley
Prev: EPICS: Visualization David Dudley
Next: Re: EPICS: Visualization Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: EPICS: Visualization Dalesio, Leo `Bob`
Next: EPICS: trying to build asyn 4-6 David Dudley
