1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: EPICS: trying to build asyn 4-6
To: <[email protected]>
Date: Mon, 11 Sep 2006 09:23:45 -0500
Trying to build Asyn-4.6 on Linux.
Here's what happens (annotated logfile):
make -C configure install
make[1]: Entering directory `/home/daviddu/local/src/EPICS/modules/soft/4-6/configure'
perl ~/local/src/EPICS/base/configure/tools/convertRelease.pl -h linux-x86 checkRelease
make -C O.linux-x86 -f ../Makefile TOP=../.. T_A=linux-x86 install
make[2]: Entering directory `/home/daviddu/local/src/EPICS/modules/soft/4-6/configure/O.linux-x86'
make[2]: Nothing to be done for `install'.
make[2]: Leaving directory `/home/daviddu/local/src/EPICS/modules/soft/4-6/configure/O.linux-x86'
make[1]: Leaving directory `/home/daviddu/local/src/EPICS/modules/soft/4-6/configure'
make -C makeSupport install
make[1]: Entering directory `/home/daviddu/local/src/EPICS/modules/soft/4-6/makeSupport'
make[2]: Entering directory `/home/daviddu/local/src/EPICS/modules/soft/4-6/makeSupport/O.linux-x86'
make[2]: Leaving directory `/home/daviddu/local/src/EPICS/modules/soft/4-6/makeSupport/O.linux-x86'
make[1]: Leaving directory `/home/daviddu/local/src/EPICS/modules/soft/4-6/makeSupport'
make -C asyn install
make[1]: Entering directory `/home/daviddu/local/src/EPICS/modules/soft/4-6/asyn'
make[2]: Entering directory `/home/daviddu/local/src/EPICS/modules/soft/4-6/asyn/O.linux-x86'
~/local/src/EPICS/base/bin/linux-x86/dbToRecordtypeH  -I . -I .. -I ../../dbd   ../../asyn/asynRecord/asynRecord.dbd ../O.Common/asynRecord.h
Error   Last token ""dbCommon.dbd""
input line:     include "dbCommon.dbd"
   in: file ../../asyn/asynRecord/asynRecord.dbd line 107
filename="../dbLexRoutines.c" line number=388
No such file or directory dbIncludeNew opening file dbCommon.dbd
dbCalloc: callocMustSucceed(0, 2) - bad args
Thread _main_ (0x8052878) can't proceed, suspending.
make[2]: *** [../O.Common/asynRecord.h] Interrupt
make[1]: *** [install.linux-x86] Interrupt
make: *** [asyn.install] Interrupt
EPICS_HOST_ARCH=linux-x86
configure/RELEASE file contains:
#RELEASE Location of external products
#  IPAC is only necessary if support for Greensprings IP488 is required
#  IPAC release V2-7 or later is required.
# IPAC=/corvette/home/epics/devel/ipac/2-8
# SEQ is required for testIPServer
#SNCSEQ=/home/phoebus/NORUME/src/EPICS/modules/soft/seq
#  EPICS_BASE 3.14.6 or later is required
LINUX_GPIB=NO
# EPICS_BASE=/home/phoebus/NORUME/src/EPICS/base_R3_14_2_branch
EPICS_BASE=/home/daviddu/local/src/EPICS/base
Shouldn't 'base' show up as an include directory in the call to 'dbToRecordtypeH'?  Thats where 'dbCommon.dbd' is at.
Same thing happens with the '_cvs' version.
David Dudley
BEGIN:VCARD
VERSION:2.1
X-GWTYPE:USER
FN:David Dudley
TEL;WORK:880-3740
ORG:;MIS
TEL;PREF;FAX:880-3741
EMAIL;WORK;PREF;NGW:[email protected]
N:Dudley;David
END:VCARD
Re: EPICS: trying to build asyn 4-6 Eric Norum
Prev: Re: VME Bus Error handling on MVME3100 and MVME6100 boards Kate Feng
Next: Keithley 6221 Pulsed current source Sibley III, Coles
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: EPICS: Visualization nda
Next: Re: EPICS: trying to build asyn 4-6 Eric Norum
