Ralph,
1. PATH in environment of my Windows computer has
<EpicsBase>\bin\win32-x86 and I called makeBaseApp.pl (not just
makeBaseApp).
2. The example with full path doesn't work.
C:\testioc>dir
Volume in drive C has no label.
Volume Serial Number is E886-E139
Directory of C:\testioc
09/26/2006 10:41 AM <DIR> .
09/26/2006 10:41 AM <DIR> ..
0 File(s) 0 bytes
2 Dir(s) 22,611,488,768 bytes free
C:\testioc>c:\epics\base\bin\win32-x86\makeBaseApp.pl -t example example
Can't find EPICS base
C:\testioc>
3. I didn't have the problem with 3.14.01, 3.14.4 and 3.14.7. I suppose
something was changed.
4. I can't search solution ... I am sorry.
Thanks, Andrei.
-----Original Message-----
Sent: Tuesday, September 26, 2006 4:26 AM
To: Liyu, Andrei
Cc: EPICS-tech-talk
Subject: Re: Epics 3.14.8.2 for Windows still has problems
Hello Andrei,
Please note that for the first call in a new TOP area, you have to call
makeBaseApp.pl with the full path name, i.e.
<EpicsBase>\bin\<arch>\makeBaseApp.pl -t example example
(see chapter 2.6.1 on page 17 of the 3.14 Application Developer's
Guide).
For subsequent calls to makeBaseApp.pl in an existing TOP area, the
definitions in the configure/RELEASE file will be used.
If you call makeBaseApp.pl through an entry in your PATH variable, the
script will not be able to locate the base installation where it is
installed, i.e. its own position.
So - I'm sorry, but at the moment I don't really see anything to fix.
If you find a solution for the makeBaseApp.pl script to find its own
location even when called through a PATH entry, I guess we'd be more
than happy to include it in the next release.
Cheers,
Ralph
Liyu, Andrei wrote:
> Ernest Williams found way to work with Windows/CMD(not cygwin)/VC++
8.0/Epics 3.14.8.2. I have tested with Windows/CMD(not cygwin)/VC++
7.0/Epics 3.14.8.2.
> 1. Simple "makeBaseApp.pl -t example example" doesn't work.
> 2. "makeBaseApp.pl -b <EpicsBase> -t example example" doesn't work.
> 3. "makeBaseApp.pl -T <EpicsTemplate> -t example example" doesn't
work.
> But "makeBaseApp.pl -b c:\epics\base -T
c:\epics\base\templates\makeBaseApp\top -t example example" does work.
> Please, fix that.
> Thanks, Andrei.
> C:\testioc>makeBaseApp.pl -T c:\epics\base\templates\makeBaseApp\top
-t example example
> C:\testioc>makeBaseApp.pl -b c:\epics\base -T
> C:\testioc>dir
> 09/25/2006 03:09 PM <DIR> .
> 09/25/2006 03:09 PM <DIR> ..
> 09/25/2006 03:09 PM <DIR> configure
> 09/25/2006 03:09 PM <DIR> exampleApp
> 09/25/2006 03:09 PM 400 Makefile
> 1 File(s) 400 bytes
> 4 Dir(s) 22,654,251,008 bytes free
c:\epics\base\templates\makeBaseApp\top -i -t example example
> Using target architecture win32-x86 (only one available)
> The following applications are available:
> example
> What application should the IOC(s) boot?
> The default uses the IOC's name, even if not listed above.
> Application name? example
> C:\testioc>
- Re: Epics 3.14.8.2 for Windows still has problems Andrew Johnson
- Re: Epics 3.14.8.2 for Windows still has problems Ralph Lange
Re: Epics 3.14.8.2 for Windows still has problems Ernest L. Williams Jr.
<2006>
2025
<2006>
2025
