Liyu, Andrei wrote:
2. The example with full path doesn't work.
C:\testioc>dir
Volume in drive C has no label.
Volume Serial Number is E886-E139
Directory of C:\testioc
09/26/2006 10:41 AM <DIR> .
09/26/2006 10:41 AM <DIR> ..
0 File(s) 0 bytes
2 Dir(s) 22,611,488,768 bytes free
C:\testioc>c:\epics\base\bin\win32-x86\makeBaseApp.pl -t example example
Can't find EPICS base
C:\testioc>
What happens if you use this command instead?
perl \epics\base\bin\win32-x86\makeBaseApp.pl -t example example
I suspect that Windows may be stripping the path information from the
command line when you just type the name of a script, whereas the above
allows perl and hence the script to see the full path to the script.
- Andrew
There is considerable overlap between the intelligence of the smartest
bears and the dumbest tourists -- Yosemite National Park Ranger
- RE: Epics 3.14.8.2 for Windows still has problems Liyu, Andrei
<2006>
2025
<2006>
2025
