1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: Re: VME Bus Error handling on MVME3100 and MVME6100 board
To: [email protected], [email protected]
Date: Fri, 06 Oct 2006 13:47:34 -0400
Andrew Johnson wrote :
> The Raven will be capable of detecting and reporting the following
errors
> to one or more MPC masters:
> * MPC address bus time-out
> * PCI master signalled master abort
> * PCI master received target abort
> * PCI parity error
> * PCI system error
> Each MERST error bit may be programmed to generate a machine check
> and/or a standard interrupt.
According to the document, Discovery chips do provide four hardware
signals which can detect the above errors (except for the MPC address
bus time-out). Those signals could have been wired to the MCP
(machine Check) input of the PowerPC processor.  In case of
error detection, address and data are latched in specific registers
for debugging as well.  I have been waiting for Motorola to verify how
the MCP signals are wired on the MVME5500 and MVME6100 boards.
Kate
Prev: EPICS Training at USPAS Andrew Johnson
Next: sequencer installation Emmanuel Mayssat
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
ANJ, 02 Sep 2010 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
