You are right, the registrar function was missing.
1/ Compile the snl program to turn it into a c program
(In this program there is a epicsExportRegistrar command )
2/ Include the c source from 1 into the IOC code by editing the IOC
Makefile
3/ compile
4/ start the IOC, with a dbd file that includes the registrar function
5/ ... it works ...
I was actually starting the ioc executable without doing a
dbloaddatabase(<... dbd file>). So the registrar function was not
executed.
E
On Fri, 2006-10-06 at 16:17 -0500, Eric Norum wrote:
> Did you:
> a) Create a .dbd file with a registrar command for the sequence
> program? For example, I've got an sequencer source file with 'program
> scanAcqPll' at the top and a scanPll.dbd file containing:
> registrar(scanAcqPllRegistrar)
> b) Add that .dbd file to your application. Using my system as an
> example again, the application Makefile contains the line:
> rftest_DBD += scanPll.dbd
> BTW -- my application Makefile also contains:
> rftest_SRCS += scanPll.st
> and
> rftest_LIBS += seq pv
> c) Do a make distclean ; make
> On Oct 6, 2006, at 1:41 PM, Emmanuel Mayssat wrote:
> > Here again, I have to deal with the not-s-straight-forward epics
> > build
> > system.
> > So far I always build against the base. I am referring to the
> > configuration and/or config directories at the top my device source.
> > In those files the SNC make variable is not set etc.
> > The sequencer source build correctly but against a local
> > configuration/config directory.
> > So far I was able to go from snl to c code and include the c code in
> > my
> > driver source. But, when I type "help" at the iocsh prompt I do not
> > see
> > the sequencer commands (such as seqShow, etc).
> > 1/ Where are those commands coming from? A library ?
> > 2/ I include the seq pv seqDev libraries in my ioc. My sequencer.c
> > program is also added as a SRCS to that same ioc. Everything compile
> > correctly. But still cannot see the seqShow command in the iocsh
> > help.
> > What am I not doing correctly ?
> Eric Norum <[email protected]>
> Advanced Photon Source
> Argonne National Laboratory
> (630) 252-4793
- sequencer installation Emmanuel Mayssat
- Re: sequencer installation Eric Norum
RE: sequencer installation Mark Rivers
<2006>
2025
<2006>
2025
