Zhan,
For each module in synApps that can be built on win32-x86 there is a
RELEASE.win32-x86 file. For example in the calc module:
corvette> pwd
/home/epics/devel/calc/2-6-3/configure
corvette> more RELEASE.win32-x86
#RELEASE Location of external products
# Run "gnumake clean uninstall install" in the application
# top directory each time this file is changed.
TEMPLATE_TOP=$(EPICS_BASE)/templates/makeBaseApp/top
# EPICS_BASE usually appears last so other apps can override stuff:
EPICS_BASE=H:/epics/base-3.14.8.2
# Need recDynLink
SSCAN=J:/epics/devel/sscan/2-5-3
# Need genSubRecord
GENSUB=J:/epics/devel/genSub/1-6
#Capfast users may need the following definitions
#CAPFAST_TEMPLATES=
#SCH2EDIF_PATH=
>From the above you can see the syntax that we use.
I have been building for win32-x86 with the Cygwin bash shell, but I
think that the DOS shell should also work.
> -----Original Message-----
> From: Zhang, Zhan [mailto:[email protected]]
> Sent: Saturday, October 07, 2006 4:00 PM
> To: Mark Rivers; [email protected]
> Subject: RE: Failed to install sequencer 2.0.11 on WIN32
> Mark,
> Thanks for your response!
> Actually, I am quite confused about how to set the path in the
> file 'RELEASE' or 'MASTER_RELEASE'. I tried 'C:\CGWIN\base-3.148.2',
> 'C:\\CGWIN\\base-3.14.8.2', 'C:/CGWIN/base-3.14.8.2', and
> '/base-3.14.8.2'. I forgot all the details but somehow I decided to
> settle with the '/base-3.14.8.2'. I assumed that is a valid form
> because it seems to me paths like '/usr/local' are recognized
> (I assume
> C:\CGWIN is the root). Is this correct at all?
> I did a quick check on the four different expressions and the
> first one (with '\') does not work, but the second '\\' and the third
> '/' both ended up with same error message, which is different
> from what
> I got previously--
> make -C configure install
> make[1]: Entering directory
> `/usr/local/synApps_5_1_1/support/seq/2-0-11/configure'
> perl C:\\CGWIN\\base-3.14.8.2/configure/tools/convertRelease.pl -h
> win32-x86 checkRelease
> perl C:\\CGWIN\\base-3.14.8.2/configure/tools/makeMakefile.pl
> O.win32-x86 ../..
> perl C:\\CGWIN\\base-3.14.8.2/configure/tools/mkdir.pl O.Common
> make -C O.win32-x86 -f ../Makefile TOP=../.. T_A=win32-x86 install
> make[2]: Entering directory
> `/usr/local/synApps_5_1_1/support/seq/2-0-11/configure/O.win32-x86'
> win32-x86 CONFIG_APP_INCLUDE
> win32-x86 RULES_INCLUDE
> make[2]: Leaving directory
> make[1]: Leaving directory
> make -C src install
> `/usr/local/synApps_5_1_1/support/seq/2-0-11/src'
> make -C pv install
> `/usr/local/synApps_5_1_1/support/seq/2-0-11/src/pv'
> O.win32-x86 ../../..
> make -C O.win32-x86 -f ../Makefile TOP=../../.. T_A=win32-x86 install
> make[3]: Entering directory
> `/usr/local/synApps_5_1_1/support/seq/2-0-11/src/pv/O.win32-x86'
> make[3]: Leaving directory
> MakefileInclude:95: *** target pattern contains no `%'. Stop.
> make[2]: *** [install.win32-x86] Error 2
> make[1]: *** [pv.install] Error 2
> make: *** [src.install] Error 2
> I could not figure out what corresponses to 'MakefileInclude:95:
> ...' This might be the reason I opt for '/base-3.14.8.2'
> format, which
> seems carrying on a bit further.
> Any suggestion?
> Thanks!
> Zhan
> >Zhang,
> >I'm not sure that the LNK4044 warning is the problem.
> >However, this line suggests the problem:
> >cl /nologo /EHsc /GR -c -DPVCA /D_CRT_SECURE_NO_DEPRECATE
> >/D_CRT_NONSTDC_NO_DEPRECATE /D__STDC__=0 /Ox /GL
> > /W3 /w44355 /MD -I. -I.. -I..\\..\\..\\include\\os\\WIN32
> >-I\\base-3.14.8.2\\include\\os\\WIN32
> >-I\\base-3.14.8.2\\include /Tp ..\\pvCa.cc pvCa.cc
> >It looks to me like it is looking for EPICS base in the wrong place,
> i.e. \\base-3.14.8.2, with no dirve specification, rather
> than something
> >>like
> >C:\EPICS\base-3.14.8.2.
> >How have you defined EPICS_BASE in seq-2-0-11/configure/RELEASE?
> >Mark
> Zhan Zhang
> Argonne National Laboratory
> X-ray Science Division
> Bldg 438, D005
> 9700 S. Cass Ave
> Argonne, IL 60439
> Tel: (630) 252-0863
> Email: [email protected]
- RE: Failed to install sequencer 2.0.11 on WIN32 Zhan Zhang
Re: sequencer installation Janet Anderson
<2006>
2025
<2006>
2025
