1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: RE: Multihomed IOC
To: "'Emmanuel Mayssat'" <[email protected]>, "'epics'" <[email protected]>
Date: Fri, 3 Nov 2006 09:37:54 -0700
Emmanuel,
> I run an IOC on computer with 2 network interfaces.
> When I try to caget a process variable I get an error telling me that
> the PV is accessible from 2 addresses (multiple servers warning).
I could imagine seeing that result if you have configured your network
interfaces to (both of them) be on the same subnet, and caget is being run
on another host on this subnet?
Alternatively, if you are running caget on the same multi-homed host as the
IOC then it might be necessary to explicitly configure the client's address
list so that it does not broadcast on both subnets (and find the same IOC on
both subnets)? And of course, you could just avoid running clients on
machines that are also routers. In some situations maybe dedicated routers
are cheap enough that we can avoid using workstations for this purpose?
> I tried to
> EPICS_CA_AUTO_ADDR_LIST=NO
> EPICS_CA_ADDR_LIST=<myHostname>:5064
> But then I get the message:
> Empty PV search address list.
> and cannot find the PV at all.
This (the empty search address list message) is not my experience here
(testing on Linux). Admittedly I am not running on a multi-homed host, but I
don't expect that would cause the address list to be empty when it is
explicitly configured as follows.
~$ export EPICS_CA_ADDR_LIST=wombat:5064
~$ export EPICS_CA_AUTO_ADDR_LIST=YES
~$ caget joh:fred
joh:fred                       0.0066983
Jeff
> -----Original Message-----
> From: Emmanuel Mayssat [mailto:[email protected]]
> Sent: Thursday, November 02, 2006 7:53 PM
> To: epics
> Cc: [email protected]
> Subject: Multihomed IOC
> Hello,
> I tried to
> It doesn't make any sense!
> Please help,
> Emmanuel
RE: Multihomed IOC Jeff Hill
Multihomed IOC Emmanuel Mayssat
Prev: Re: HP8116A signal generator Kate Feng
Next: AAI/AAO database information David Dudley
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Prev: Re: Multihomed IOC Maren Purves
Next: RE: Multihomed IOC Jeff Hill
ANJ, 02 Sep 2010 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
