Eric Norum wrote:
First, a general reply to all the kind folks out there who wrote with
suggestions. It's good to see that the EPICS community is still
hanging together.
Second, to summarize the results, I'm still unable to get things to
work. The plan is now to replace this obsolete generator with a more
modern piece of equipment.
I do not have the hardware and software, and
do not know what the IOC platform is. However,
there are two more things you can check for GPIB devices:
1) Some GPIB device driver uses the on-board DMA to transfer
command. If so, one has to make sure that the "hardware
cache snoop" is on. The howto depends on the SBC that is used.
2) There is a restriction on the total length of the cables in the
system. One can isolate the problem by using the shortest
cable with only the targeted GPIB device attached to test.
Kate
On Nov 3, 2006, at 6:26 AM, David Maden wrote:
Eric Norum wrote:
All my memories of GPIB horrors are returning.
I've put together ASYN/devGPIB support for an (obsolete) HP8116A
signal generator. I'm trying to communicate with the generator
through an Agilent E5810A GPIB/LAN adapter. As far as I can tell
I'm sending the correct strings but the generator never acts upon
the commands. Every once in a very long while it will return a
status message in response to a command, but most of the time it
just sits there. Once in a while it sets the SRQ line and then
leaves it set forever.
Does anyone out there have experience with HP8116A GPIB communication?
Hi Eric,
I have no experience with the HP8116A, but I do have quite a bit of
experience of GPIB devices in general and the Agilent E5810A in
particular. My experience has been that HP devices have well behaved
GPIB interfaces (not surprising really, since HP invented the GPIB).
I would suggest that you first try to understand how to communicate
with your device using basic RPC calls to the E5810A before trying
to tackle the complications of ASYN/devGPIB. You may find the
program described at:
<http://www.sls.psi.ch/controls/help/howto/gpib_test.html>
Thanks.
I don't think that this is an ASYN/devGpib problem. I tried to issue
commands through the web interface built in to the E5810A even then
was unable to get the 8116A to communicate. I know that the 8116A is
capable of GPIB communication because it works with the PCMCIA GPIB
interface in a laptop. I know that the E5810A is capable of
controlling devices because it can communicate with other devices on
the bus.
of some use when doing this, though I'm afraid that it won't help
with SRQ issues. It is based on routines originally written by
Benjamin Franksen of BESSY. You can find the code at:
<ftp://ftp.psi.ch/PSI_outgoing/maden/gpib_test.tar.gz>
I downloaded and built this. Here's what I get when I run it:
1) Try to read the complete settings from the 8116A:
norume@worthy 366> GPIB_HOST=GPIB2GWDIAG1 GPIB_ADDR=gpib0,8 ./
gpib_test sr CST
device_read result = 15 (I/O time-out)
Bytes read = 0
2) Try to read the frequency setting from the 8116A:
norume@worthy 367> GPIB_HOST=GPIB2GWDIAG1 GPIB_ADDR=gpib0,8 ./
gpib_test sr IFRQ
Bytes read = 0
3) Try to read from another device -- it appears that the test
program and E5810A really do work:
norume@worthy 368> GPIB_HOST=GPIB2GWDIAG1 GPIB_ADDR=gpib0,4 ./
gpib_test sr "*IDN?"
ICS Electronics, 4823B, S/N 011255, Rev X0.10 Ver 99.11.24\n
4) Try the 8116A again -- this time with a newline at the end of the
command:
norume@worthy 369> GPIB_HOST=GPIB2GWDIAG1 GPIB_ADDR=gpib0,8 ./
gpib_test sr "IFRQ\n"
Bytes read = 0
norume@worthy 370> GPIB_HOST=GPIB2GWDIAG1 GPIB_ADDR=gpib0,8 ./
gpib_test sr "CST\n"
Bytes read = 0
5) And again -- this time with a carriage return at the end of the
command:
norume@worthy 371> GPIB_HOST=GPIB2GWDIAG1 GPIB_ADDR=gpib0,8 ./
gpib_test sr "CST\r"
Bytes read = 0
norume@worthy 372> GPIB_HOST=GPIB2GWDIAG1 GPIB_ADDR=gpib0,8 ./
gpib_test sr "IFRQ\r"
Bytes read = 0
Looks to be completely unresponsive. :-(
I could break out the GPIB bus analyzer and look into this further
but time constraints make it easier to just buy a replacement signal
generator.
Oblibatory ASYN advertisement -- the asynRecord and associated MEDM
screens provide similar diagnostics for checking out GPIB communication.
- HP8116A signal generator Eric Norum
- Re: HP8116A signal generator David Maden
- Re: HP8116A signal generator Eric Norum
Re: HP8116A signal generator Kate Feng
RE: Multihomed IOC Jeff Hill
<2006>
2025
Re: HP8116A signal generator Till Straumann
<2006>
2025
ANJ, 02 Sep 2010 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
IRMIS
Talk
Documents
Links
Licensing
