1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: Re: Motion control failure at APS
To: Emmanuel Mayssat <[email protected]>
Cc: EPICS <[email protected]>
Date: Mon, 13 Nov 2006 14:15:02 -0600
The OMS VME58 is susceptible to noise on the limit switch lines.
This has been the most frequent problem that I have been called on
the diagnose.
Kurt Goetze and I did some testing to see if this is a problem with the
MAXv.  Of course we can't quantify it, but it appears that OMS has
done a much better job with the MAXv on this issue.
Ron
Emmanuel Mayssat wrote:
I actually had the exact opposite problem.
My motor controller would barely start a move.
The limit switches were reported as not closed, and the apparatus was in
a safe position to operate. The problem was due to glitches on the limit
switch cables (we actually never observed those glitches). The problem
was reproducible in a controlled environment (engineering bench). As of today, we think it was due to cable length and cross talking.
We rebuild and shortened the cables. It immediately worked.
Food for thoughts and... time for lunch,
Emmanuel
On Mon, 2006-11-13 at 12:56 -0600, Mark Rivers wrote:
Folks,
We have seen failures in the past where a motor moved constantly at a
slow rate right past limit switches on an OMS58. It happened only on a
single axis, not on all 8 axes.
RE: Motion control failure at APS Mark Rivers
RE: Motion control failure at APS Emmanuel Mayssat
Prev: RE: Motion control failure at APS Emmanuel Mayssat
Next: Re: Motion control failure at APS Josh Stein
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Next: RE: Motion control failure at APS Mark Rivers
ANJ, 02 Sep 2010 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
