I had the same problem on FC5 with kernel 2.6.18-1.2200FC5_SMP.
I tried edm 1-11-0m and 1-11-0p ...
They all behave same.
The debug info doesn't show much information:
> > > [pengs@dhcp-216-102 ~]$ gdb
> > > /ade/epics/supTop/extensions/R3.14.8.2/bin/linux-x86/edm
> > > GNU gdb Red Hat Linux (6.3.0.0-1.134.fc5rh) Copyright 2004 Free
> > > Software Foundation, Inc.
> > > GDB is free software, covered by the GNU General Public License,
> > > and you are welcome to change it and/or distribute copies of it under certain conditions.
> > > Type "show copying" to see the conditions.
> > > There is absolutely no warranty for GDB. Type "show warranty" for details.
> > > This GDB was configured as "i386-redhat-linux-gnu"...Using host libthread_db library "/lib/libthread_db.so.1".
> > > (gdb) run
> > > Starting program:
> > > Reading symbols from shared object read from target memory...done.
> > > Loaded system supplied DSO at 0x953000 [Thread debugging using
> > > libthread_db enabled] [New Thread -1208948512 (LWP 3633)] [New
> > > Thread -1209087072 (LWP 3662)] [New Thread -1208951904 (LWP 3661)]
> > > Program received signal SIG32, Real-time event 32.
> > > [Switching to Thread -1208951904 (LWP 3661)]
> > > 0x4932fa08 in clone () from /lib/libc.so.6
> > > (gdb) bt
> > > #0 0x4932fa08 in clone () from /lib/libc.so.6
> > > #1 0x003d0f00 in ?? ()
> > > #2 0x00000000 in ?? ()
> > > (gdb)
Strace shows the program gets into the problem everytime when it tries to load particular font.
So I installed all possible fonts. Then edm works fine for me now.
Help this would help.
Thanks.
Sheng
- Re: Segment fault for edm 1-11-0s Dirk Kraemer
- Segment fault for edm 1-11-0s Dirk Kraemer
- Re: Segment fault for edm 1-11-0s John William Sinclair
Incorrect display of Y label of X-Y Graph in edm Jianguo DING
<2006>
2025
<2006>
2025
