Benjamin Franksen wrote:
On Friday 24 November 2006 19:49, Billy Adams wrote:
OpenMotif was not included in Fedora Core 6 released in Oct.
2006, as expected. But all is not lost yet. EPICS R3.14.8.2 can be
compiled and executed using Fedora Core 6.
I installed "ALL OPTIONS" when installing Fedora Core 6.
Installation took a little less than 6 Gigabytes. The only thing
else needed is OpenMotif.
I took the following two RPM files from Fedora Core 5
installation CD4 and installed them on Fedora Core 6:
openmotif-2.3.0-0.1.9.2.i386.rpm
openmotif-devel-2.3.0-0.1.9.2.i386.rpm
Next I compiled EPICS R3.14.8, then the facility code, and
executed the facility code. It works!
FWIW, installing openmotif-2.3.0 (beta) from source (on an amd64
debian-testing) went absolutely straight forward for me. In contrast to
older versions of OpenMotif, which had a strange build system, the
latest versions needs only the usual './configure; make; make install'
routine. (You might, however, need to install one or two additional
devel packages from your distro.)
I compiled openmotif-2.3.0 on MacOSX 10.4.8/Intel and it was straight
forward too.
Now I can run medm and edm on my MacBook with X11 from Apple.
To build edm on this environment, I needed to modify
libCom/osi/epicsMutex.cpp. But I don't know if it is proper way to fix
the problem I encountered.
To build EPICS and its extensions on Knoppix5, I also use openmotif-2.3.0.
Ben
Noboru Yamamoto
EPICS group/J-PARC contro group
KEK, JAPAN
Noboru
- Fedora Core 6 & EPICS R3.14.8.2 Billy Adams
- Re: Fedora Core 6 & EPICS R3.14.8.2 Benjamin Franksen
Edm 1-11-0s GOURNAY Jean-Francois DAPNIA
<2006>
2025
vmivme5565 driver for epics 3.13 Lei Ge
<2006>
2025
ANJ, 02 Sep 2010 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
IRMIS
Talk
Documents
Links
Licensing
